Forget-me-not Mug
Intro: Forget-me-not Mug
My mum collects mugs and cups with forget-me-not flowers. Each time it is more difficult to find one she doesn't have yet so I've decided to make her one out of felt. (Luckily she doesn't drink from them!)
Materials:
- 9"x12" sheet of felt in light colour (natural, beige, flesh, white...)
- felt in green and light blue (cut offs are fine)
- yellow beads (optional)
- matching thread: natural, light blue, green, yellow
- contrasting (or matching) embroidery thread (I used light blue)
- iron on Vilene (optional)
- scissors
- needle
- pins
Materials:
- scissors
- needle
- pins
STEP 1: Measuring and Cutting
I'm not very good at measuring so I traced an existing enamel cup onto the paper and then cut it out of felt.
Light felt- The mug
- 2x 7.5 x 25cm (3" x 10")
- 2x circle ∅ 8 cm (3")
- 1x 3 x 12cm (1,2" x 5")
Vinele (optional)
- 1x 7.5 x 25cm (3" x 10")
- 1x circle ∅ 8 cm (3")
Blue felt- Flowers
- about 15 tiny flowers (with 5 petals)
Green felt- Leaves''''
- about 8 small leaves in drop shape
Light felt- The mug
Vinele (optional)
Blue felt- Flowers
STEP 2: Stem and Leaves
Take one of the big rectangles and embroider (stitch) stem + add leaves.
(Before I started I've done some sketches on the paper how the stem should look like, which way to go...)
STEP 3: Flowers+Vilene
Add flowers and yellow beads as the centre of each flower. If you don't have beads, just stitch yellow centre with thread.
Iron Vilene on the other side of this decorated piece.
Iron on Vilene on one of the circles as well.
STEP 4: Handle
Stitch the handle using the baseball stitch.
STEP 5:
Put both rectangles on each other, decorated side facing up. The length of the inside felt should be shortened by 2-5mm depending of the felt thickness (otherwise the inside felt will wave) .
Using the ladder stitch sew shorter sides together.
STEP 6: Adding the Handle
Add the handle. Mine is the shape of question mark. Make sure your stitches wont show inside the mug- keep the needle between both felt layers.
STEP 7: Adding the Bottom
Tricky bit! Take both circles (with Vilone ironed inside) and stitch it to the roll- bottom of the mug. Make sure you stitch all 4 pieces of felt together all the time!! Use matching thread and blanket stitch.
STEP 8: Final Step
Using contrasting (or matching) embroidery thread finish the top edge of the mug using blanket stitch.
3 Comments
porcupinemamma 14 years ago
Sandisk1duo 15 years ago
m-art-ina 15 years ago
