Forging a Scorpion From a Lag Bolt
Intro: Forging a Scorpion From a Lag Bolt
Part two of my blacksmithing series. How to forge a scorpion from a lag bolt.
these things are fairly quick to make (when you get used to them), look cute, and sell fairly well as you can price them for a fairly low price, and still get money for your time and supplies.
Have fun with it !
Part 1 in the series was forging a J hook - https://www.instructables.com/id/Forging-a-J-hook/
Part 3 will be forging an S hook
Have fun with it !
STEP 1: What You Need.
You need -
-basic forging supplies (forge, anvil, hammer, tongs, chisels, punches, etc.
-lag bolt (I like 3/8"x3", but you can use what you want for different sized scorpions). If you use galvanized lag bolts, make sure you soak them in vinegar at least for a day. If you try to forge them without removing the galvanization with acid, the zinc fumes from the galvanization are POISONOUS!
-spray paint or beeswax (for finishing. On this one I'll use paint, but I typically use the beeswax finish. Namely, melting beeswax over the warm metal)
STEP 2: The Tail End
Heat it up, and begin flattening. flatten the tail end (the pointy side) first. After it's flattened, you need the bring the end to a point.
STEP 3: Flatten
Go ahead and flatten the rest of the lag bolt now. When it's nice and flat, as well as evenly flat, make sure everything is nice and straight. As you can see in the photos, the head became askew some, but I fixed that by heating it, clamping the head in the vise, and driving the lower portion in the correct direction.
STEP 4: Make the Claws
Split the flattened head partially down the middle. Then use the chisel to cut a groove down the middle of each little "wing" . If I confused you here, look at the pics.
STEP 5: Embellishments
use a small punch to punch in the eyes. Then use a flat tipped round punch right at the end of the cut from splitting the claws, this will give almost a little beak look when you bend the claws.
Now you heat the head, and using pliers, twist them around so the groove is facing out. and bend them out a little until they look nice. take a little time and mess with them till they look good.
STEP 6: Curl the Tail
using pliers or your anvils horn (I like to use the horn now that I've learned how to place my blows, but early on in teaching myself blacksmithing, I used pliers), curve the tail of the scorpion up and over. Try to give it a nice wicked curve. Once again, play with it a little till it looks good,
STEP 7: Finishing
Now, your done. Wire brush it real good, and finish it in one of two ways. Either give it the beeswax finish I described in my J hook instructable, or do as I did on this one, and spray paint it a nice glossy black.
24 Comments
aschmidt13 10 years ago
cool. not going to make it since I have no forging skills, but it's cool. And using the screw: good idea.
3366carlos 11 years ago
jlund 12 years ago
oldanvilyoungsmith 12 years ago
Here is a simple tutorial about a forge like I described http://paleoplanet69529.yuku.com/topic/36358
Stephen
jlund 12 years ago
So the efficiency dosnt really matter that much. And what do you use for an anvil I'm just gonna make one from the 1/2 inch steel plates he has that I cut up to make shapes and stuff
Stephen
pfred2 12 years ago
My anvil was all beat up so I milled it.
http://i.imgur.com/W9BUl.jpg
Then I polished the horn with a grinder.
http://i.imgur.com/sbIwS.jpg
It really isn't that hard to do. Someday when I'm really bored I'll eventually clean up the whole thing. It is boring, but not hard.
jlund 12 years ago
everyday im shuffling, except fridays, i got to get down on friday 12 years ago
BuildIt6000 12 years ago
ARJOON 12 years ago
kube60 12 years ago
Stephen
lbrewer42 12 years ago
mikeasaurus 12 years ago
Also, this scorpion would make a sweet coat hook, just like a J-hook! I'd love to have a few of these crawling up my wall, waiting to hold my hat or coat!
splazem 12 years ago
