Introduction: Fork Lockout Mod Part 1
The RST F1RST Air 29 shock has a lockout knob on the top right of the fork stanchion it's nifty. But I didn't like how it was indexed and don't have a very good feel. It also seemed to limit the lockout adjustability . This is my hack.
This modification may void your fork warranty if you have one. Don't attempt to do this unless you're okay with that. Yup
Step 1: Undo the Mini Alan Screw.
I did this mod before a night ride hence the darkness and absence of my normal bike tools.
Step 2: Pry Up the Knob CAREFULLY!!!
Life only gives you one knob. Don't make lemonade that you have to spill over later.
Step 3: You Will See This. It Is a Ball Bearing on a Spring
If you ever want to undo this mod don't lose the two balls or springs.
Step 4: These Are the Parts You Should Have.
1-knobbie thingie
1plastic circular plate with ditches on one side and wordie-pictureish things on the other
2- springs of differing winding
2- steel balls.
1- screwy thing
Step 5: So for Some Reason They Put a Bunch O Holes in There
I stored the springs and balls in the holes for later .
Step 6: Turn the Post Counter-clockwise Till It Stops.
It shouldn't be but a half turn till it stops. This is your upper limit. Locked out.
Step 7: Flip the Plastic Thingie Around
So no more bumpies
Step 8: Put It Back Together and U Are Done!
Now you have an infinite number of lockout settings!
Next when I get some time ill be making a remote lockout for this fork. Stay tuned!
As always: do this at your own risk, don't be stupid, if you aren't quite sure about something ask a buddy for help.
