Introduction: A Fork for Cutting and Eating Food Using Only One Hand
A fork attached to the clip
Its purpose is to grab food that requires cutting with a knife.
sting the food with the fork and attach the clip to the plate, the food is fixed to the plate and with the same hand the food can be cut, The user can eat the cuted bite
The process continues until the food is finished
Materials
2 forks
Strong stainless steel metal clip with anti-slip material
Solder materials
3 mm metal pin (Depending on the type of clip you choose)
Tools
Soldering material (silver)
Metal saw
Sandpaper
Metal pipe
Wooden hammer
Step 1: Cut the Fork 5 Cm From the End Tip With the Metal Saw
Step 2: Open the Clip to 2 Parts. Put the Spring Aside
Step 3: Smoothed the Piece at the Catted Tip
Step 4: Bend the Second Fork According to the Drawing, by Hand
Step 5: Bent the Fork Teeth Using the Metal Pipe and a Wooden Hammer
Step 6: Solder the Fork Piece to One Side of the Clip, As in the Picture.
The purpose of connecting this part, is to produce a convenient grip and opening of the clip
Step 7: Attach the Fork
Attach the fork to the other part of the clip so that the bending is at the end of the clip (griping side), as in the picture
