Introduction: Four Blade Paper Fan
Hi friends, greetings from Shalini
Today I have come up with a small idea on how to do a four blade paper fan. Without any future delay let us see what are the items required to do this.
Materials required:
1. 4 strips of cardboard sheet 15cm X 3cm
2. 4 lean strips of color paper
3. Film cans ( or bottle caps)
4. Wooden skewer
5. Press button
6. Flat refill
7. Old CD/DVD ( or cardboard )
Step 1: Preparation
Step 1:
First we have to cut out the KG cardboard into 4 strips in the measurement of 15cm in height and 3cm in breadth, here instead of film cans I have used bottle caps, using a hot glue gun we have to stick them and should insert a hole in it. Instead of pen refill and press button we can also use straws and one of the straw should be closed on one end
Step 2: Preparing of Blades
Step 2:
The cardboard strips should have to stuck one on another as shown in the image. Draw a diagonal line and slightly crease them inward. Put a hole in middle of them and insert straws. The straw which is closed on one side should be placed inside the top blade.
Step 3: Base
Step 3:
As we have discussed in the first slide we can even use bottle caps instead of film cans.
Stick them one on the other, put a hole inside the caps to insert the wooden skewer and stick them. Prepare a base using CD/DVD then stick this above the base.
Step 4: Blades
Step 4:
After attaching the straw attach the lean strips of paper to them in a curved manner.
