Introduction: Frankenstein Guitar Amp Build
About: A chronicle of ideas and projects from a designer and thinker in repurposing obsolete technology and discarded materials. Professional Musician, Grad student at NYU's ITP program, co-creator of the TapeScape…
This is called the "Frankenstein Amplifier" because I had a couple of amp cabinets with speakers and no working amplifiers, plus some other bits and pieces that were just waiting to be reduced and combined.
I wired a Crate GX15 into 3 separate speakers instead of 1, and turned a pair of old computer speakers into an overdriven 2nd channel.
Step 1: Gluing and Compressing the Plywood Speaker Panel
I had plenty of 3 ply wood lying around, but this wasn't quite up to the task of handling 5 speakers with heavy magnets in them.
So I cut identically sized pieces, spread a thin layer of wood glue between them, and (as you can see in the pic) clamped the hell out of them! Once dry and trimmed to size, the profile was seamless.
Step 2: Components Used for the Build
1. Creative SBS20 Computer Speakers and amp
2. Crate GX15 amplifier and speaker
3. Speaker from a Champion 600 amp
4. Other 4" speaker
Step 3:
The holes that were cut for the cabinets the speakers original were housed in served as great templates to stencil and cut the new holes.
Holes were cut with an electric drill and jigsaw.
Step 4:
These are the controls from the computer speakers being mocked up for housing fabrication - I used an angle grinder to cut the basic shape out of the Fender Champion housing, then used cobalt drill bits to make the holes for the potentiometers.
Lucky the potentiometers were threaded, so I was able to firmly attach the whole circuit board to the housing.
Step 5:
Here the housing is trimmed to size - I used the pre-existing holes to screw the housing in vertically to the cabinet, but needed a horizontal fastening point to make it a bit more stable.
I don't have any metal bending equipment, so I put the faceplate in my bench vise, then attached my vise grips to the tab hanging out, and bent it 90 degrees - it wasn't a bad way to do it...
Step 6: Completed Housing Fabrication
The crystal-looking thing is the chopped-of end of a christmas light - the existing LED light from the computer speakers was affixed to the inside of the christmas light with hot glue, and it now glows a soothing verdant hue when switched on.
Step 7: Jumping the Signal Off the Headphone Out
The Crate amplifier turns it's main speaker output off when you plug in headphones. To bypass this, I soldered output leads directly to the contact points on the headphone jack. These went into the computer speaker input, so now I could control whether or not I wanted to engage the (very distorted and nasty) computer speakers or keep it with a cleaner tone.
Step 8: Re-use and ReDecorate!
I used the framed grill cloth from a different amplifier, which as a bit on the small side. So I filled in the gaps with some green pen carcasses I had hung onto after they bit the dust as writing implements.
Attached it all using hot glue.
Step 9: The Finished Product in Action!
