Introduction: Freaq FM Synth
In my last build I made the awesome Mutant Synth. If you thought that project was good then wait to you see/hear the Freaq FM Synth!
First and foremost - I need to do a huge shoutout to MeeBleeps who designed this amazing synth. All I'm doing is creating a PCB and front panel of my own and solving a few issues that I encountered. The following Instructable will take you step by step on how you can build your own. I've included all of the files needed including the gerber files for the PCB and front panel along with the Arduino sketch which you can find in my Github
The front panel is a Eurorack design so if you are into modular synths then this synth would fit perfectly into your rack! It can be run from 12V power supply and also has a power connector used on on Euroracks.
It also can be used as a standalone synth and hand on heart, holds up to most mini synths you can buy.
The plan with these builds is to make my own dumbed down Eurorack which will contain a number of modules all running from 9V power supply. This will include a drum synth, looper, power rail and mixer. At the moment I have the Mutant and Freaq completed and will post on Instructables the rest of the modules and final build once ready.
Hang-on I haven't even talked about what the Freq can do.
The Freaq features dual independent 2-operator FM voices paired with a 2-track generative sequencer. You can stack the voices so they are in unison or have them in different polymeric step-counts. This allows you to have one voice play bass and the other lead.
This is one funky little machine! There are a tonne of controls and waveforms along with attack/delay envelope and LFO per voice.
In the last step you can find the user guide. I'm still a novice myself but every time I play it I find something new and I'm literally blown away by the sounds this little machine can make!
I've created a parts list which can be found in my Github and in the PDF file attached to this step. The PDF includes links and images of each of the parts which will make it easy to order the correct ones for this build.
PARTS:
- PCB - I've designed one for this build with the information on how to print your own in the next step
- Front Panel - The panel is also a PCB so you'll also need to get this printed as well - check out the next step
- Arduino Nano - Ali Express
- Capacitor Polypropylene 100nf X 2
- Capacitor Polarized 100uf X 1
- Capacitor Polarized 1000uf X 1
- Resistor Metal Film 10K X 1
- Resistor Metal Film 270R X 1
- Potentiometers 9mm Vertical 10K X 6
- Switch Momentary (PN SKRCADD010) X 8
- On/Off Toggle Switch Through Hole version X 1
- LED Dot Matrix (TZT MAX7219) X 1
- Female Header Pin Socket 15 Pin X 2
- Audio Socket 3.5mm (PN - PJ-301M) X 3
- Mini JST Connector and wire 2 Pin X 11
Step 1: PCB, Front Panel & Schematic
Firstly, all the files that you need to build your own Mutant synth can be found in my Google Drive. This includes the parts list, Gerber files for the PCB & front panel, schematic, Arduino script etc.
The build consists of 2 PCB’s – one is for the components and the other the front panel. You’ll need to send the Gerber files to a PCB manufacturer like JLCPCB (Not affiliated) who will print the boards for you. Jump into my Google Drive link, download the 2 Gerber files to your computer and then send them off to your PCB manufacturer of choice.
If you have no idea how to do this well, I've put together an Instructable on how to get your broads printed which you can find here.
NOTE: The manufacture will include an order number on both the PCB and front panel. It doesn't really matter where it is on the PCB but you don't want it on the front on the front panel!
Over at JLCPCB you can 'specify a location' once the Gerber files have been loaded so click this for the front panel and the manufacturer will add it to the back where I have indicated.. You can also just hit 'No' when asked if you want to remove the order number. However, this costs $2.
Step 2: Adding Components to the PCB
The PCB is 2 sided. The front has all of the active components like the pots and switches and the reverse has the passive components like the Arduino, caps and resistors. As some of the components are underneath the Arduino and (9v battery holder (if you install it), you have to be aware of the order that you solder parts into place.
Let's start with the reverse side and add the passive components:
STEPS:
- Always start with the lowest profile components - in this case (in probably all cases!) it's the resistors - all 2 of them!. Solder them all into place and check the values before soldering so you don't have to troubleshoot the parts later if something goes wrong!
- Solder the JST header into place.
- Solder the capacitors into place ensuring the polarities are correct on the electrolytic caps.
- You may have also noticed that there is a double row of holes (16) in the board as well. This is in case you want to power it via a Eurorack power board.
- Now you can add the header pins for the Arduino. The best way to do this is to connect the header pins to the Arduino and then place them into the PCB and solder into place. This way they will be straight and in the correct position
Step 3: Adding More Components to the PCB
Now that you have done the back of the PCB, it’s time to move to the front and add all of the active components.
STEPS:
- Let’s start with the LED Dot Matrix. If you remove the LED matrix from the circuit board it is attached to, you can see indicated ‘In’ and ‘Out’. You can chain these modules together which is why they also have an out. You need to connect the 'In' pins to the RHS solder points in the PCB. There are solder points to attach header pins to both the 'in' and 'out' on the LED matrix. I included header pins to each to ensure that the matrix was securely in place to the PCB
- I wanted to make sure that the module wasn't sticking up too much through the front panel so I removed the plastic surrounds on the pins in order for the module to sit lower on the PCB.
- Also, the LED matrix has a polarity so make sure you put it back onto the circuit board the right way. If you don’t it will turn on a few LED’s but nothing will happen.
- Next, solder the 3.5mm Jacks into place
- Now you can solder all of the momentary switches into place along with the toggle switch
- Lastly, add the pots and solder them into place
That’s it for the hardware. Before you go and add the front panel, let’s load up the sketch to the Arduino.
Step 4: Importing an Older Version of Mozzi Library to Arduino IDE
When the sketch was created for the Freaq Synth, it used an older version of Mozzi. The most recent version isn’t compatible and when you try to upload it you get a bunch of error codes. To counter this, you need to install an older version of Mozzi to Arduino IDE.
NOTE - the images attached are for the mutant synth but it's the same thing for the Freaq synth
1 First, go ahead and uninstall Mozzi 2.0 if you have it installed in Arduino IDE and also uninstall FixMath if you have this as well. If you are unsure how to do this, then check out this link:
https://support.arduino.cc/hc/en-us/articles/360016077340-Uninstall-libraries-from-Arduino-IDE\
2 You now need to install Mozzi 1.1.2 to Arduino IDE. Look up 'Mozzi' in the library manager search bar and then go to the dropdown and hit version 1.1.2 (see image 1)
3 Go ahead & install Mozzi 1.1.2 via the dropdown
4 If everything worked you should now have Mozzi 1.1.2 imported to your Arduino library. If not, then have another go at it following the steps above. The screenshots I have provided should help as well so take a look at them if you are confused or a little lost.
Step 5: Uploading the Sketch to Your Adruino
STEPS:
- Go to my Github, open the Arduino Sketch folder and download the MutantFMSynth folder onto your computer
- Go into the folder and hit the MutantFMSynth.ino file. This will open Arduino IDE and will also include the other file extensions such as the header and .ccp files which are also in the folder you downloaded
Side note – I didn’t think the .ccp files were needed so I initially deleted these from the folder. Big mistake – they are needed to ensure the header files are detected!
- The Arduino sketch should have all of the files from the MutanFMSynth like in the image.
- Hit the upload button and load the sketch to your Arduino Nano.
- If all goes well, you’ll get the always-good-to-see ‘upload complete’ message.
- If not, then you’ll need to do a bit of troubleshooting to find out what the root cause of the issue is.
Now it's time to add the Arduino to the PCB and give it a test run.
- If you haven’t already, connect the Arduino to your PCB and power it up. Note that the PCB runs off 9V’s so you can connect a variable power supply or just use a 9V battery if you want.
- Plug a speaker into the out jack on the synth
- Turn the synth on via the toggle switch and press the ‘start’ button.
- You should see a bunch of lights on and hear sounds coming out the speaker.
- The instructions on how to play the synth can be found in the last step.
- Now you can play around with the controls and discover a few of the sounds that this synth can make!
Step 6: Adding the Front Cover & Knobs
If the synth is working as it should and you are hearing some funky tunes, then you are ready to add the front panel on. As mentioned before, I have used the Eurorack form factor on the front panels so they (should) fit into any Eurorack frame. However, You can also make a case for it from wood which I have done for many similar builds or you can make a bare bones case which I have done for this build
STEPS:
- Carefully place the front panel over the components on the PCB. It should fit on perfectly!
- Now you can add the nuts to the potentiometers and also to the on/off switch and 3.5mm jack sockets. This will keep the panel in place!
- Now add the knobs to the potentiometers. Use small ones as the larger type will take up too much room and will make it hard to get your fingers in there and turn them.
- I also added some legs to the front panel so it would sit nice and flat when I was playing it. I'm going to add this synth along with others in a later build to a case.
Step 7: How to Play the Freaq Synth
Instructions
Buttons
[Func][Rec] + buttons - Access various secondary functions
Start - Start or stop the sequencer
[Func] + Start - Tap tempo
Tonic - Select tonic through natural notes A - G
[Func] + Tonic - Shift base octave from 0 - 5
[Func][Rec] + Tonic - Select octave offset to Track 1 (track 1 & 2 can be 0-4 octaves apart)
Scales - Select current musical scale
[Func] + Scales - Select current generative algorithm
[Func][Rec] + Scales - Select the LFO waveform for the current voice
Rec + knob - Hold down while moving a knob to record those parameters to the sequence
[Func][Rec] + knob - Hold down while moving a knob to delete the recorded sequence for that parameter
[Func][Rec] + Start - Select the MODULATOR waveform for the current voice
Voice - Select the active track which can be edited using the parameter inputs
[Func] + Voice - Select the FM ratio mode for the current voice
[Func][Rec] + Voice - Select CARRIER Waveform for the current voice
Potentiometers
Mutation - Adjust the likelihood that the sequence will change over time
[Func] + Mutation - Adjust the likelihood that any given step will be a note or a rest
Density - Adjust the number of steps for the active track
Seq 1 – Adjust the steps for track 1
[Func] + Seq 1 + 2 - Adjust the number of steps for all tracks
Note Length - Adjust the length of the notes (for all tracks)
Ratio - Select the carrier--to-modulator FM ratio (based on the current FM mode)
LFO - Adjust the amount of LFO to apply to the modulator level for the active track
[Func] + LFO- Adjust the LFO rate for the active track
Attack - Adjust the attack time for the modulator level envelope
Decay - Adjust the decay time for the modulator level envelope
Depth - Adjust the amount of envelope to apply to the modulator level for the active track
Step 8: Last Words
There is so many great sounds that you can get out of this little synth. Play around, experiment and use the instructions in Step 8 to help you understand all of the functions.
You probably noticed I didn't talk at all about a case. I did add some legs to the front panel to make it easier to play but the plan is to make my own 'poor mans' (I have to come up with a better name) Eurorack that runs off 9V power supply and anyone can build and play.
Next in line to build is my Groove Box synth which you can see in the vids. After that will be a mixer and power rail and then some type of case. I'd love to use some vintage tech for the case but I haven't been able to find what I want (at least for the price I want it at). If I can't I'll build my own. Oh, I also want to add a looper/sampler module as well which will allow me to add my own little touches to the sound.
I'll continue to to publish each part on Instructables so keep a look out for those upcoming projects.
