Introduction: Free Archery Target
This is my build version of a free archery target I came across on you tube.This is a Really easy up-cycle project and can be built for free.
This is similar in construction to the layered carpet targets but we will be layering cardboard sections and binding them tight and housing this stack inside a cardboard box.
Step 1: Gather Some Cardboard... Lots of Cardboard...
For this build you will need:
- Cardboard box (Of suitable target size) to use as the Enclosure Box
- Additional Corrugated cardboard
- A knife to cut the cardboard
- Duct tape
The only suitable box for an enclosure we had laying about was one that a crock pot came in and it measures ~14" x 14" x 12".
Luckily I found enough cardboard to fill this enclosure all n all I'd estimate this fairly small target box took nearly 40 square feet of cardboard to fill!
But this also makes for a great project for repurposing cardboard that may get trashed.
Step 2: Cut Filler Sheets & Bale
This step is easy and will take a little time especially if you plan to make a big target.
Simply cut sheets from your filler cardboard the size of the interior footprint of your enclosure box.
Learn from my mistake and be a little conservative. The filler we are making doesn't have to fit super snug to the inside of the enclosure box. If the final bale is too big you will tear up your enclosure or have to trim the bale. I did both.
Once you have a stack of cardboard sheets about 4" thick compress the stack down and tape the bungle together with duct tape.
Tape the bundle along the what will be the side walls of your stack not the target face.
Repeat this step and tape your individual bundles together to make 1 bail the size of your enclosure box.
Step 3: Seal the Enclosure
Once the filler bale is complete place it in your enclosure. I had some plastic shipping material I placed in the bottom of my enclosure to reuse and take up a little space. Also helped the bale fit nice a snug.
Close up the enclosure box and duct tape the flaps using multiple passes.
Next wrap enclosure in tape around side walls , top and bottom to reinforce holding the bale inside compressed.
YOU ARE DONE!!
The target is useable at this point the next step is just to add a little production value.
Step 4: Finishing Touches
Now lets add some production value.
This step is optional but will extend the life of your new free target and it will look sweet.
Start by covering enclosure box exterior with duct tape. I wanted a black target to have good contrast I did not have black tape but I did have some black plastic paint. After coving the box I sprayed the tape black.
The target face will have to be replaced after many uses so cut a panel out of the face and duct taped the along the edge that was left. And around the removable panel. The target panel was then taped back into place. The whole face was painted again and a target image I found on the inter-web was printed on some neon paper I had and hung.
Done!!
Summer #mikehacks Contest
Green Design Contest
9 Comments
7 years ago
Whats the difference in shooting into the cardboard layered or stacked
Reply 7 years ago
Shooting 'between' stacked layers slows the arrow down relatively gently.
Shooting into a face of a bundle the arrow has to puncture each layer = very fast decel can fracture or weaken your arrows.
At lower poundage and if the bundle is not really compacted it may not make a differance.
8 years ago on Introduction
Hahaha this is perfect!
9 years ago on Introduction
Super smart...got my son a bow and can see the foam target wont last much longer! :)
works great especially for lower poundages. only problem i had was shooting wooden arrows without a flush point, so i ripped it up within a 100 arrows. works better with carbon tho!
9 years ago
I like It! Might be a good project for me this weekend.
I use phone books. I just toss a bunch of old phone books into a box.
9 years ago
Thanks but I cannot take credit for the idea I first saw this on the boarriorbows YouTube channel. It was fun to build.
Great idea!
