Introduction: Freeformable Circuit | Real Freeform Circuit!
A freeformable IR remote-controlled LED circuit. An all-in-one applicable DIY light chaser with Arduino-controlled patterns.
Story:
I have been inspired by the freeform circuit... So I just made a freeform circuit that is even freeformable (can be formed into any shape and design). This circuit is a 18 LED chaser in which patterns are changeable with IR remote. Each LED can be controlled separately.
Step 1: Forming Into Shape
As I designed for a hexagonal frame I shaped it using pliers and used graph for reference.
Step 2: Arduino Preparation
Remove the Arduino pins and braces with cutter and pliers. Desolder pins from the Arduino Nano don't break it!
Step 3: Frame Joining
I soldered a four copper rods on the screw hole of arduino with the USB port GND to the hexagonal frame.
Step 4: Preparing LED Arms
I soldered LED's with the wires and used 330ohms resistor for each LED.
Step 5: Joining All Parts
Finally each LED wire is soldered with frames.
(LED -ve to the frame)
Step 6: IR Receiver Part
The TSOP1738 IR receiver is mounted on top of Arduino Nano's ISP head And output pin to the Arduino Rx pin.
Step 7: Final Pinch
I have messed on soldering part on the frame since copper doesn't allows the soldering to bind together.
I suggest to use Brass rods for better results.
Don't use thick soldering leads! it will surely get in trouble...
Get in Touch
Follow me and have questions or suggestion?
Contact me via my Instagram profile: https://www.instagram.com/itz_me_stark/
