Introduction: French Onion Mini Pies
I love caramelized onions. I've shown something similar to these in an older instructable using phyllo shells. These really do deserve their own instructable, though. They hold up well, taste great warm or room temperature, and seem to disappear fast at potlucks.
I think pastry crust would be a bit heavy for these, so I tend to use plain bread. These are easiest to eat if they're baked in bite sized mini cupcake tins, with a toasted bread crust holding all the onions in.
To make these, you will need:
16 slices of bread
3 large onions (I use yellow, whether regular or sweet)
2-3 T butter
a splash of apple cider (maybe 1/4 cup, more if you want more apple flavor to brighten the onion)
1/2 C or more of beef stock, preferably low sodium
4-8 oz shredded white cheese, depending on how much you like to add - I suggest mozzarella, provolone, swiss, havarti, or a combination of any of those
a few grinds of black pepper
thyme (optional)
bay leaf (optional)
16 slices of bread
2-3 T butter
thyme (optional)
bay leaf (optional)
Step 1: Make Crust
I had a loaf of bread that got really squished. I cut one circle of each piece of bread I used. This left a lot of bread scraps. Don't waste these. Using a bread knife, cube them to toast for croutons (for homemade stuffing/dressing). If you won't use them in the next day, just bag up the bread cubes and freeze them.
Depending on your preference, you can either roll the circles flat with a rolling pin or squish them flat as you press them into the muffin tins. Either way, lightly butter the bottom side to keep them from sticking, and to add a nice golden brown color to the crust.
Step 2: Cook the Onions
Cut onions in half from root to tip. Cut off the tip from each half, then peel off the dry outer skin. Slice the onions into quarter circles, starting at the tip end and working your way toward the root.
Melt a couple tablespoons of butter in a pan over medium heat and add onions. Stir every so often to make sure they don't burn. This part will take awhile. It would help to sprinkle a teaspoon of salt over the onions, but be careful. If your beef stock is salty, this might make the onions too salty. Let the onions gently cook down and turn a golden color. Add the thyme and bay leaf, if using. Grind on some black pepper.
After the onions are an even golden hue, add the apple cider and beef stock. Continue to cook the onions, letting the liquid evaporate. Once the onions are soft and the liquid has turned into a sticky glaze, taste them. Add salt if needed.
Step 3: Fill and Bake
Preheat oven to 400 degrees F.
Use a spoon to scoop the onion mixture into the crusts. Press the onion gently down to get rid of air pockets. These work best if the onion mixture is kept dense.
Sprinkle cheese over the onion pies. Make sure to clean up any onion or cheese that lands on the pan. It's a pain to scrub off after it's been baked on.
Bake for a few minutes until the cheese is melted and starting to turn golden. You can serve these warm or at room temperature.
Thanks for reading!
Thanks for reading!
