Introduction: Fried Chicken Recipe
The Ultimate Fried Chicken Recipe: Crispy On The Outside With Crunchy Crust, Juicy And Tender From Inside, And Irresistibly Tasty. To Top All That, It’s So Simple To Make Them.
There’s nothing quite like biting into a piece of perfectly fried chicken; crispy on the outside, juicy on the inside, and packed with flavor. Whether you’re preparing for a family dinner, a picnic, or a casual get-together, fried chicken is always a crowd-pleaser. Today, I’m sharing my easy fried chicken recipe that guarantees to deliver every time. So, roll up your sleeves, and let’s get frying!
What Makes Fried Chicken So Delicious
Fried chicken’s deliciousness can be attributed to several key factors that together create an irresistible combination of flavors, textures, and aromas. Here’s a closer look at what makes fried chicken so mouthwatering:
CRISPY COATING
The crispy coating is perhaps the most iconic feature of fried chicken. This is achieved through the use of a seasoned flour or batter that crisps up when fried. The contrast between the crunchy exterior and the juicy interior provides a satisfying texture that is hard to resist.
JUICY INTERIOR
Marinating the chicken helps to tenderize the meat and keep it juicy during the frying process. The marinade penetrates the chicken, adding flavor and moisture, which results in a tender and flavorful bite every time.
FLAVORFUL SEASONING
Fried chicken is often seasoned with a blend of herbs and spices. This seasoning is mixed into the flour for the coating, ensuring every bite is packed with flavor.
MAILLARD REACTION
The Maillard reaction is a chemical reaction that occurs when proteins and sugars in the chicken are exposed to high heat, resulting in browning and the development of complex flavors. This reaction is what gives fried chicken its deep, savory taste and appealing golden-brown color.
FAT FOR FLAVOR
Frying the chicken in oil adds another layer of flavor. The fat used for frying can impart a rich taste and helps to carry the flavors of the seasoning and chicken. The right type of oil, like peanut or vegetable oil, ensures a neutral taste while providing the perfect environment for frying.
This is an easy recipe for making flavorful, juicy and crunchy fried chicken at home. The recipe calls for some herbs and spices but most of them are pantry friendly.
To make this delicious chicken fry, you’ll need the following ingredients:
- Chicken – Thigh and drumsticks are the juiciest parts of a chicken and makes the best fried chicken.
- Salt – Adjust salt according to your taste.
- Black Pepper – Adds slight heat to the chickens.
- Garlic Powder – Adds not only flavor but helps remove bad odor of poultry as well.
- Paprika – Gives smokey color and flavor to the dish.
- Egg – Gives a binding for the chicken and flour coating.
- Water – Is used to thin the wet mixture.
- Flour – All purpose plain flour will do the job.
- Ginger Powder – This is a flavor enhancing spice.
- Onion Powder – Adds depth of flavor to the dish.
- Mustard Powder – Adds depth of flavor to the dish but you can skip if you do not have it to hand.
- Oil – Any flavorless oil will do the job.
INGREDIENTS
Chicken Marinade
- 1 Kg Chicken Thighs
- 1 tsp Salt
- 1/2 tsp Black Pepper Powder
- 1 tsp Paprika Powder
- 1 tsp Garlic Powder
Wet Mixture
- 1 Egg
- 1/2 Cup Water
- 1/4 Cup Flour
Crispy Flour Coating Mix
- 1 & 1/2 Cup Plain Flour
- 1 tsp Ginger Powder
- 1 tsp garlic Powder
- 1 tsp Onion Granules
- 1 tsp Salt
- 1 tsp Mustard Powder
- 1 & 1/2 tsp Paprika Powder
- 1 tsp Black Pepper Powder
- 300 ml Oil
Step 1: MARINATE THE CHICKEN
The secret to juicy fried chicken starts with a good marinade. In a large bowl, combine chicken pieces with salt, black pepper, paprika and garlic powder and mix well. Cover the bowl and marinade for an hour.
Step 2: PREPARE THE WET MIXTURE
In a separate bowl, beat one egg with 1/2 cup water and 1/4 cup flour and make a thin wet mixture.
Step 3: PREPARE THE CRISPY COATING
In a separate bowl, tale flour and add ginger powder, garlic powder, onion powder, paprika powder, salt, mustard powder and black pepper powder and give a toss to combine.
Step 4: HEAT THE OIL
Pour the oil into a deep frying pan and heat up. When you see tiny bubbles are forming, it’s ready. You can also use a thermometer to ensure right temperature which is 350°F (175°C).
Step 5: COAT THE CHICKEN
Dip chicken pieces into wet mixture for few seconds and then coat them in flour mixture. If required, press and coat to ensure a proper coating is done for crispiest chicken fry.
Step 6: FRY THE CHICKEN
Carefully place the coated chicken pieces into the hot oil, a few at a time, making sure not to overcrowd the pan. Fry the chicken for about 12-15 minutes, turning occasionally, until the outside is golden brown and the internal temperature reaches 165°F (75°C). Transfer the fried chicken to a wire rack set over kitchen towel or a baking sheet to drain any excess oil.
Step 7: SERVE AND ENJOY
Let the fried chicken rest for a few minutes to ensure the juices redistribute throughout the meat. Serve hot with your favorite sides like mashed potatoes, coleslaw, or cornbread.
Perfect Fried Chicken at home with such a simple recipe and with all fresh ingredients. Chicken pieces should be perfectly cooked from inside and all juicy with crispy skin that has that chicken fry crunch.
- Pro tip: Make sure to fry them as soon as you coat them in flour mixture.
- Pro tip: It’s important that oil is enough hot when putting in the chicken pieces.
- Pro tip: Do not compromise on oil, make sure the chicken pieces are almost slinked in oil.
Storing Leftover Fried Chicken
Fried chicken are everyone’s favorite and most of the time are finished in one go. However, if you have leftover chicken fry you can store them properly to enjoy another day.
- Refrigeration: Store leftover fried chicken in the fridge for 2-3 days. Make sure it’s covered properly and in an air tight container for staying fresh for longer.
- Freezing: If you want to keep your delicious crispy chicken fry for a longer period, consider freezing it. Put them in a zip lock bag. Label and date the packages before storing them in the freezer for up to a month.
Find the full recipe with tips in my blog and also many more useful easy to follow recipes:
https://bublisworldcuisine.com/fried-chicken-recipe/
If you like this easy crispy fried chicken recipe, you might like my other recipes too. I would like to invite you to subscribe to my mailing list which is absolutely free. It will help you get updates on all my future posts. Next time when I post a similar recipe or something interesting you will get notified if you are on our mailing list. Thank you for checking my blog post.
