Introduction: Fried Ice Cream
One night I got bored and decided to make fried ice cream. It is one of my favorite desserts, so I figured I should learn how to make it. It didn't take to long, only about an hour or so.
You will need:
Vanilla Ice Cream
Corn Flakes
Coconut Flakes
Cinnamon
Chili Powder
Some cooking Oil
and a Candy thermometer
You will need:
Vanilla Ice Cream
Corn Flakes
Coconut Flakes
Cinnamon
Chili Powder
Some cooking Oil
Step 1: Forming the Balls
You can only do this with your hands. Clean and wash them, then start scooping out ice cream. I wanted them fairly big,m so I tried to make them about plum sized. After they are done place back into freezer, they have to stay frozen solid or they won't fry. Keep them in there for about half an hour, on to the next steps.
Step 2: Making the "Crust"
Grab a bowl and fill it with about a cup of corn flakes. I crushed them by hand, but I bet it would work much better if you pour them into a bag and crush. Break the flakes down into small pieces, I kept a few odd ones for texture. Once you've reached your desired consistency add other ingredients. I put in about a half cup unpacked coconut, put more in if you like. Then about a teaspoon of cinnamon, I just went by sight. Lastly a pinch of chili powder, this gives it that little bit of spice.
Step 3: Assembly
Beat an egg in a small bowl. Pull out the ice cream balls from the freezer, hopefully they are solid. Roll each ball into egg, and then flake mixture. I repeated to make sure I had the entire ball covered. Back into the freezer till hard.
Step 4: Frying
Heat the oil in a pan, attach thermometer. Heat up to 375 degrees. I did some tests using tortillas, they tasted pretty good too. The tortillas also lowered the temperature, so keep that in mind. Take out solid ice cream balls from freezer. Carefully lower into oil with spoon. They cook really fast, make sure to flip them over if your pan is shallow. Take them out when they are a dark golden brown and crispy. Let them cool, and enjoy!
You can add syrup our whipped cream, I just ate them plain.
