Introduction: Friendly Face
I created a friendly face that lights up for my brother who is afraid of the dark. He always sleeps with the lights on and it wastes a lot of power, so I created this fun little friend for him to have so he isn't eating away at my college savings with his power consumption.
- Transparent 3D Printing Filament
- Laptop with Fusion 360
- 3D Printer
- A good attitude
- Gorilla Glue
- Mini electric candle (Tea Lamp)
- Sharpie
Step 1: Create in Fusion
- Open Fusion 360
- Create a project
- Create a primitive sphere with a loop length of 3.922
- Create a sketch of a circle that is the circumference of the sphere
- Create a plane on the x axis halfway into the sphere
- Create a secondary circle sketch on the new plane that matches the previous sketch
- Cut the circle in half on the same sketch
- Revolve a cut around the center line, leaving 1.9in of depth in the original sphere
- Create a .6in diameter circle sketch separate from the original sphere
- Extrude that .2inches up
- Create a sketch of a square around the circle, .6in on each side
- Extrude the square .1in up
- Create two circles with a diameter of .4in and place them on the previously created plane, towards the back of the sphere
- Extrude both of those circles, .4in double sided
- On the y plane, create two sketches of several attached triangles on top of the extruded circles on the rear of the circle.
- Extrude each of those sketches .075in on two sides
- Filet each triangle edge .025in
- Create two circle sketches with a .4 diameter on the bottom of the sphere,towards the negative x plane
- Extrude each circle .2in
- Create a sketch of a line .3in, starting at the center of the extruded circle going towards the negative x plane
- Repeat step 20 on the second circle
- Create a pipe using one of the lines, with a diameter of .2in
- Repeat step 22 for the second line
- Create a hole in the top of the sphere, .22in deep with a diameter of .6
- On the z axis, create a fit point spline that resembles an upside down smiley face
- Join extrude that sketch .006in
- Create two circles with a diameter of .1in centered on the cylinders at the bottom of the object
- Cut Extrude each of those circles .15in into the cylinders
- Create a triangle sketch on the XZ axis towards the center front of the sphere
- Extrude that sketch .1in on each side
- Fillet the corners of the triangle .05in on every edge
- Have a celebratory smile, you're done!
Step 2: Printing
In this step, you print the design to your local 3D printer. Personally, I sent it to my teacher and he printed it because I do not have access to a 3D printer.
Step 3: Coloring
We all have a little inner childlike desire that wants to color, and part of this design fulfills that desire. Just take a sharpie and color the nose, eyes, and smile to add some depth to the object
Step 4: Add Light
Take a plastic Tea Lamp and use gorilla glue to attach it to the hole in the bottom of the friendly face.
