Friendly Robot (ICARUS Robot)
Intro: Friendly Robot (ICARUS Robot)
- material selection
- the material I choose
- why did I choose it?
- Introduction
- how did we think about this project?
- how do we select the project?
- how do we do the storyboard?
- how did we deal with issues?
- software selection & machine using
- cad design
- design the body on Solid Works or Fusion 360 (preferred)
- prepare the body (STL)file on Cura
- print the body
- circuit design
- wiring diagram using fritzing
- design PCB on eagle (hat for Raspberry Pi 3 model B)
- computer vision coding
- definition of computer vision
- OpenCV library and its uses
- Installing important libraries
- Face recognition explanation
- Hand recognition explanation
- The whole code
- google assistant code
- mobile app
STEP 1: Introduction
As usual, before I go into details about this project, I will discuss with you the process before making this project, the process I love to call on it, the selection process
Selection process contains
- how we think in this project
- how we select the project
- how we did the storyboard
- how we deal with issues
- technical selection
I studied the project as it's known as (project management) it's organized procedures that let you study projects very carefully and accurately, and I will try to give you thoughts about what happened behind the scenes
How we think in this projectwhen we decided to make a project (at first, we hadn't decided yet which project we would choose) we intended to make it like ROMBA (its cleaning robot)
We want to make an automatic smart robot.
After buying ROMBA and doing reverse Engineering on it (that examines every part in the ROMBA robot and determines the function of every part)
We watched an ad for a robot called Vector
What makes us admire this project is that it's an interactive Robot, small, and very cute
So we were confused about which one we would choose to make and then we got a wonderful idea.
As I said earlier, we had a smart idea, the team and I decided to make a combination with both of them
We decided to make our ICARUS ROBOT
ICARUS ROBOT is not like both ROMBA and VECTOR, it's had some features of ROMBA and some others of VECTOR
We were excited to start building the board and study the project and guess what, that's exactly what we did
StoryboardSimply what we want this robot to do is
To be interactive
Connected with mobile application
Connected with WIFI
Connected with Google Assistant
So, we started to warm up and make some prototypes to see how it worked and absolutely we faced issues and problems
And as I make in all of my documentation, I will tell you our failures before success, to avoid everything wrong we did
STEP 2: Cad Design
In this part, we will learn how to design the robot on CAD software
How did we think about the body?
Before you think anything you should know this, you must take the measurements of your components to know how the body dimension will be Figures (1),(2),(3)
As smaller it is, as better it was
As we finished the measurements and prepared our dimensions, we could imagine the body, so we had to body to be smaller and artistic we found one that looked exactly as we describe
Figure (4)
So, we will make our body look closely like that
We had the measurements and a vision of the body so, let's build our FABY Robot
Let’s begin with the head, the head must include the camera and OLED screen so will design the head to contain all of these components in Figure (5)
now we need to think of a mechanism that allows the head to move up and down, luckily for you, we will give you this mechanism in Figure (6)
So let’s see our mechanism on the head figure (7)
Let’s prepare our components and put them in the body figure (8)
Let’s see our body now figure (9)
design the wheel and put it into the final shape figure (10)
Don’t worry I will leave all files down so you can download it
After finishing designing the body it’s time to fabricate it
To fabricate the body, you need the main thing that you will print with the filament I prefer PLA filament figure (11)
So, after you save the parts as STL files, open Cura and import these files, I will give you two examples
The first one is the mechanism of the head figure (12)
Then press save to file and take this file to flash drive put it on a flash drive and put it in the 3D printer to begin to print Figure (13)
Let’s move on to the second part that we will print which is the body of the wheel without the tire, again repeat the same steps, and import the file in cura figure (14)
Edit the filament and supports and draft as you see and press slice, you will see the average time that the part will be 3D printed in Figure (15)
Then press save the file, put it on the flash drive upload it to the 3D printer, and leave it to be printed figure (16),(17)
Then add to the wheel the rubber part which we made by ourselves figure (18), (19), (20), (21)
STEP 3: CIRCUIT DESIGN
First, before we go to PCB design we should make at first wiring diagram to know how we will connect the components with each other.
Open fritzing insert all of the components on it and start wiring (figure 1)
Complete wiring (figure 2)
So the final schematic wiring diagram (figure 3)
After we made the wiring diagram it’s time to move to the eagle cad, we will have some fun
Now we will design a hat for Raspberry Pi 3 Model B
- Select your components.
- arrange them in the most suitable way so that the pins are as close to each other as possible to avoid overlap of wires and routes.
- export your schematic to the board and get your components arranged.
*Since We're using the Raspberry Pi board as a controller, we need to make sure that the board will not overlap the pi and fit well over it.
that's why we used the component "RASPBERRYPI-40-PIN-GPIO_PTH_REFERENCE".
Components:
- 7.4 lipo battery
- step-down dc-dc converter
- 2 IR sensors
- L293D motor drive IC.
- 2 metal gear DC motor.
- Raspberry Pi 3 model B.
- 1 Ultrasonic sensor
Shield board components :
- 5 of 2 wire 5mm terminals.
- 3 of 3 wire 5mm terminals.
- 6-pin headers for the screen
After that, we will send it to the lab to be fabricated and note that (the mine track width is 0.5mm and the mine diameter hole is 0.8 mm )
After we sent it to FAB LAB it was fabricated and the result was fantastic again, don’t worry I will leave the board and schematic down in files, just click on it and download it
After we finish the PCB fabrication it’s now time to soldring the component on the PCB
Note: Thanks to Alaa Saber for providing us with all the resources, we did the PCB design with his effort so thank you again
STEP 4: Computer Vision
this part is not easy, it’s needed a lot of concentration and codes to understand how face recognition and hand recognition work
so be aware of everything I will say and I will try to give you the conclusion, not the whole idea
Note: special thanks to our lovely Amani who helped us all by herself with computer vision she explained all the procedures with marvelous words, and explained all the errors she faced, I recommend reading her article on computer vision you will find interesting videos with simple explanation just click on
Computer Vision: Computer Vision is the broad parent name for any computations involving visual content – that means images, videos, icons, and anything else with pixels involved. But within this parent idea, there are a few specific tasks that are core building blocks:
In object classification, you train a model on a dataset of specific objects, and the model classifies new objects as belonging to one or more of your training categories.
For object identification, your model will recognize a specific instance of an object – for example, parsing two faces in an image and tagging one as Tom Cruise and one as Katie Holmes
to make face & hand recognition we should install an important library called OpenCV.
What is OpenCV library?
is an open-source for computer vision and digital image processing and machine learning software library
I highly recommend to you if you don’t know what face detection is and haven’t deal with it you should visit the websites, I will leave now
Face detection with OpenCV and deep learning
These two websites will explain every small detail about using deep learning with the OpenCV library to make face detection, I shall not go into detail in this documentation because it will be very long and hard instead of I will give you short summary of it.
How to install OpenCV library?
I worked on the command prompt in Windows and just typed this one line
pip install opencv-python
I assume that you have OpenCV installed on your system.
Dlib and the face_recognition packages.
Note: For the following installs, ensure you are in a Python virtual environment if you’re using one. I highly recommend virtual environments for isolating your projects — it is a Python best practice. If you’ve followed my OpenCV install guides (and installed virtualenv + virtualenvwrapper )
then you can use the workon command prior to installing dlib and face_recognition
Installing dlib without GPU support
If you do not have a GPU you can install dlib using pip by following this guide:
Face recognition with OpenCV, Python, and deep learning
$ workon # optional
$ pip install dlib
Or you can compile from the source:
$ workon <your env name here> # optional
$ git clone https://github.com/davisking/dlib.git
$ cd dlib
$ mkdir build
$ cd build
$ cmake .. -DUSE_AVX_INSTRUCTIONS=1
$ cmake --build .
$ cd ..
$ python setup.py install --yes USE_AVX_INSTRUCTIONS
If you do have a CUDA-compatible GPU you can install dlib with GPU support, making facial recognition faster and more efficient.
For this, I recommend installing dlib from source as you’ll have more control over the build:
$ cd dlib
$ mkdir build
$ cd build
$ cmake .. -DDLIB_USE_CUDA=1 -DUSE_AVX_INSTRUCTIONS=1
$ cmake --build .
$ cd ..
$ python setup.py install --yes USE_AVX_INSTRUCTIONS --yes DLIB_USE_CUDA
The face_recognition module is installable via a simple pip command:
$ pip install face_recognition
How does face recognition work?
In order to build our OpenCV face recognition pipeline, we’ll be applying deep learning in Reviewing the entire FaceNet implementation is outside the scope of this tutorial, but the gist of the pipeline can be seen in Figure 1
Face alignment, as the name suggests, is the process of
(1) identifying the geometric structure of the faces and
(2) attempting to obtain a canonical alignment of the face based on translation, rotation, and scale
While optional, face alignment has been demonstrated to increase face recognition accuracy in some pipelines
After we’ve (optionally) applied face alignment and cropping, we pass the input face through our deep neural network:
The FaceNet deep learning model computes a 128-d embedding that quantifies the face itself.
That’s the way face recognition works.
Here is a sample of the face recognition code
And here is a video for Amani trying the code and it works yeah
In order to make hand track we need to install a library called math it’s easy to install I will leave links and codes down
How does hand track work?
In order to detect fingertips, we are going to use the Convex Hull technique. In mathematics, Convex Hull is the smallest convex set that contains a set of points. And a convex set is a set of points such that, if we trace a straight line from any pair of points in the set, that line must also be inside the region. The result is then a nice, smooth region, much easier to analyze than our contour, that contains many imperfections.
To detect the Fingers and count them.
Find the ROI(region of interest)
Hand Segmentation: Convert the video frame from BGR to HSV(or Gray)
Perform a Gaussian blur
Perform a Threshold
Find the Biggest Contour(this will be our hand)
Perform a convex hull and mark the ROI(region of interest
Count the no. of countors
Display it
Samples
very well. You can find the original code here. Then, found another source that illustrates how the counting of hand fingers' code works. You can find it here.
Now for the final step: mix the two codes together (face recognition and hand tracking)
Just bring the face recognition code and merge it with hand tracking code in one big code, don’t forget to edit the variables
Sample of code
And here is a video for Amani after she finished the whole code Here is a video of the mixed code running
STEP 5: Google Assistant Software
In this part, we will learn about Google Assistant and how to provide our FABY Robot with Google Assistant
Before anything, it’s preferred to work on the Raspberry Pi software (Linux rasspian distribution)
Make sure you plug the microphone into the Raspberry Pi
By the end of 2019 and the beginning of 2020, google posted a tutorial about how to implement Google Assistant on your Raspberry Pi https://developers.google.com/assistant/sdk/guides/library/python, I followed all the tutorial steps, I managed to make it work In this documentation I will talk about these steps, so you can follow me here or go to Google tutorial.
Configure and Test the Audio Test the microphone and speaker to make sure they are working well. To do so, Frist, open the terminal then write “a play -l” to find the card number and device number allocated for the microphone and speaker. Don’t forget to write down these two numbers for the microphone and speaker as we will need them later.
Second, Create the (asoundrc) file by writing this command “sudo nano /home/pi/.asoundrc”
on the terminal
Third, replace all the text inside it with the following text “ pcm.!default {
type asym capture.pcm "mic"
playback.pcm "speaker"
pcm.mic
type plug slave
{ pcm "hw:,"
pcm.speaker {
type plug slave {
pcm "hw:,"
Fourth, replace it with the numbers that you wrote down earlier.
Fifth, save and exit the file by clicking (Ctrl + x) then (y + Enter)
Sixth, type “alsamixer” on the terminal and raise the sound level of the speakers
Seventh, test the speakers by typing “speaker-test -t wav” on the terminal, by clicking enter you should
hear (left, Front) from the speakers then click (Ctrl + c) to stop it.
Eighth, test the microphone by recording sound by typing “a record --format=S16_LE --duration=5 --
rate=16000 --file-type=raw out.raw” on the terminal
Ninth, play the sound that you recorded to make sure the microphone works well by typing “apply --
format=S16_LE --rate=16000 out.raw” on the terminal
Configure a Developer Project and Account Settings and Register the Device Model
First, open your internet browser go to “console.actions.google.com” then select (new project) and
enter the name of your project
Third, after clicking on (REGISTER MODEL), click on (Download OAuth 2.0 credentials), save the json file
as we will need it later, then skip the specific traits options
Fourth, go to “console.developers.google.com/apis” then click on (Enable API and services), search for
Google Assistant API and enable it
Fifth, go to the authorization console screen as shown in the figure below, then select (External) then
(CREAT), then confirm your Email and save the settings
Sixth, go to “myaccount.google.com/activitycontrols” and make sure all the following are turned on
Web & app activity
Location History
Device information
Voice and audio activity
Step4: Install the SDK and Sample Code
First, open the terminal then type “sudo apt-get update” then “sudo apt-get upgrade” then install
python3 virtual environment by typing “sudo apt-get install python3-dev python3-venv” then write
“python3 -m venv env” to enable the virtual environment
Second, update the pip by typing “env/bin/python -m pip install --upgrade pip setuptools wheel”, then
activate the Python virtual environment using the source command by typing “source env/bin/activate”
Third, type in the terminal the following “sudo apt-get install portaudio19-dev libffi-dev libssl-dev”, then
Install Google Assistant SDK by typing “python -m pip install --upgrade google-assistant-sdk[samples] ”
Fourth, copy the JSON file that you downloaded and put it in “/home/pi” directory then copy its path.
Fifth, back to the terminal and make sure the virtual environment is activated then type “python -m pip
install --upgrade google-auth-oauthlib[tool]”
Sixth, type in the terminal “google-oauthlib-tool –scope https://www.googleapis.com/auth/assistantsdk-prototype --save --headless --client-secrets /home/pi/<credential-file-name>.json”, Don’t forget to
replace <credential-file-name> with the path of the JSON file.
Seventh, now you must see a URL on the terminal, open it copy the code then paste it into the
terminal
Eighth, to activate Google Assistant type “google samples-assistant-push to talk --project-id <project-id> --
device-model-id <model-id>” on the terminal Don’t forget to replace both <project-id> and <modelid> with their values from the action dashboard then go to the project settings page
STEP 6: Mobile Application
For Mobile App design, I used MIT App Inventor, because it's easy to learn and easy to use. MIT App Inventor is a great starter program for app building.
Several challenges should be included in the App:
1. Make an attractive design.
2. Converting the voice into words for commands.
3. Send a command to take a photo or record a video.
4. The robot motion control.
5. Connect to Google Assistant API.
So, I watched several videos on YouTube, such as:
- Android Tutorial: Convert Speech To Text | Speech Recognition
- Converting speech to text: How to create a simple dictation app using speech recognition
- 10 iPhone Apps for Converting Voice to Text
- speech to text : convert speech to text and vise versa
- Speech to Text : Voice Notes & Voice Typing App
- The 7 Best Android Dictation Apps for Easy Speech-to-Text:
- Speech notes
- Voice Notes
- Speech Texter
- Voice Notebook
- Google Assistant
- Speech to Text
- OneNote
- Android Speech to Text Tutorial
- Speech To Text - Android Studio - Java
- Speech Recognition using Python
- Speech to Text Conversion using MIT App Inventor 2
- speech recognition app using mit app inventor
- speech recognition android app using MIT app inventor
- MIT App Inventor 2 - Voice Recognition App
- App Inventor: Speech Recognizer and Text to Speech
- Convert voice commands to text - App-inventor Android Arduino
- converting text into orders using google assistant
- Text To Speech MIT APP Inventor
The design not work well in first, so several versions as the following:
- Version 1:
- The first Screen:
- The buttons for voice [Button3] were added, with the speech organizer to talk as Non-visible components, beside a text box for writing the voice words.
- Added ON [Button4]and OFF [Button5] buttons to control the raspberry pi GPIO pin, by adding Android thingsboard1 and Android thingsGPIO1 as Non-visible components.
- Forward [Button2] was added to go to screen 2.
- The Second screen:
- The buttons for voice [Speak Button] were added, with the speech organizer to talk as Non-visible components, beside a text box for writing the voice words.
- Added Backward [Button1] to back to Screen 1, and forward [Button2] to go to Screen 3.
- The third Screen:
- The buttons for voice [Button1] were added, with the speech organizer to talk as Non-visible components, beside a text box for writing the voice words.
- Bluetooth
- Added a Bluetooth picture [ListPicker1 button]to open the mobile Bluetooth to contact with the robot which is controlled by adding BluetoothClient1 and Clock as Non-visible components.
- Added Backward button [Button2] to back to Screen 1.
- The Cons of the design:
- It is designed for converting speaking into words, but it is so boring with poor design.
- The video testing
- Version 2:
- here I downloaded the Vector app to follow the ideal design. But the home icons are not fully organized and sending the commands still not working.
- Version 3:
- It covers all the previous challenges.
- The First Screen {Welcome screen}:
- Involves one button to go to the home screen [Screen 2]
- The Second Screen {Home Screen}:
- Includes six buttons to open the camera, Stats, Entertainment, Question and Answer mode, Interact, About.
- The Third Screen {Camera Screen}:
- Contacted with firebase database by adding in Non-visible components, by sending code {1} when pressing camera picture [Snap button] to open the robot camera and take a capture, and sending code {2} when pressing the video picture [Video button] to open the robot camera and record a video.
- The firebase was also tested by adding Name and Age in the text boxes and pressing save to save on the database.
- A camera test button was added to show the firebase response, which was done by adding Ev3touchsensor1 and camera1 as non-visible components.
- The Fourth Screen {Entertainment Screen}:
- Includes four arrows {left, right, up, and down} to control the robot's motion.
- The Fifth Screen {Question and Answer mode Screen}:
- Which will be connected with Google Assistant API
- The Sixth Screen {Interact Screen}:
- Contains the buttons for speaking [Hi_FABY], with the speech organizer to can talk as Non-visible components, beside a text box for writing the voice words.
- The Seventh Screen {About}:
- That includes information about the robot and the working team and the fabricated place.
- The video testing
- The video Testing the commands sending to firebase.
