Introduction: Friendship Bracelet With Adjustable Knots
This tutorial will help you to share friendship bracelets with your bestie :) It is really pretty and easy to make.
You and your friend can make each one and exchange them as a symbol of friendship!
Step 1: 1) Pre-steps (Materials)
1) Choose a pattern and colors you want
*I am making this fabulous pattern with black, red, and yellow colors, representing German flag*
These are the possible patterns you might want to do. Go to friendship-bracelets.net for more patterns!
2) Gather all the materials you need
- the number of strings you need for the pattern with the colors you want
- a clipboard (anything to fasten the strings)
- scissors
- tapes
- pendants (optional)
->brass sheet, fret saw, pillar drill, clamp, files (tool), permanent marker, sandpaper
☛If you want to make pendants yourself? go to the next step. ✔︎
Step 2: Making a Pendant
°This step is optional.°
Do this step only if you want to make a pendant yourself.
1) Bring a piece of brass sheet (Brass looks like gold.) Do not use a very thick one because it will be much harder to cut a shape out of it. I used a soft and quite thin brass sheet to make my pendants.
2) Sketch your shape of the pendants (whatever you want! It can be initials of a name, heart shape, etc.) The size really does not matter. My pendants are 5mm*15mm*1mm (5 wide, 15 height, 1 thickness).
3) Drill a hole that a string will go through. The hole should be larger than 1mm (diameter). I used proxxon pillar drill because it is suitable for making small holes.
4) Cut the shape of it by using fret saw. When you use fret saw, never put your power on it. You should move your hand up and down continuously without any power. The blade can break when you force the saw.
5) File it to make the edges smooth.
6) Sand the pendants to remove all scratches on the surface.
Always be careful when you use machines and tools !!!
Step 3: Cutting the Strings
Cut them all in 80cm or more. It is always good to have enough length of strings rather than running out of strings in the middle of the process.
Step 4: Making a Knot and Fastening
Lay down all your strings and make a knot at the end (but leave 5-10cm for the adjustable knot).
Clip the strings (tied together) on a clipboard. If you do not have a clipboard, it is okay. You can then use tape or anything that you can stick your bracelet on to your table.
Step 5: Braiding the Strings
You can already start with the pattern, but I recommend braiding before you do so because then it takes less time and prettier. Braid the strings for 4cm or less. Then tie them (make a knot with all strings) so that it is fastened.
Step 6: Knotting the Pattern
Use the image of the pattern from friendship-bracelets.net. There are a lot of other cool patterns as well, so go have a look there!
↘︎ this arrow means to knot the left string over the right one
↙︎ this arrow means to knot the right string over the left one
Always do "DOUBLE KNOTS" (knotting twice)
Knot the bracelet for 10cm, then make a knot (tie it) with all strings so that it is fastened.
Thread the pendants during this process if you have them.
Step 7: Braiding the Strings Again
Braid the strings again, and tie them (make a knot) when you are done with the braids.
(Repeat Step4)
Step 8: Making Adjustable Knots
Tape both ends of strings (It will be must easier to make adjustable knots)
Clip the bracelet and place the two strands like shown in the picture.
Grab the end of the upper strings and wrap around the another for 3 times, take it out of the loop and fasten. Look at the images for detail.
Do the same process for the opposite end of the string to make another adjustable knot. If you have two adjustable knots, the bracelet will be adjustable in both ways.
When you made the two adjustable knots, pull the one end and the other end several times to check if they slide smoothly and adjust the bracelet.
Step 9: Your Friendship Bracelet Completed :)
Yay!
Have fun with the bracelet!
