Introduction: Fuel Injector Cleaner Pulse Generator BOX
This is my machine pulse generator to clean injectors, made in low budget, using Arduino and some parts. It can be used in a test bench or only to operate the injectors correctly, keeping them safe while cleaning. Is easy to build so far.
It is useful for a workshop or personally, it operates 4 injectors at the same time, generating the necessary pulses while maintaining a favorable work cycle so as not to damage them or affect their correct operation.
It has 4 speeds and a constant pulse on request, (button on / off) to open the injectors to the maximum if necessary.
Buttons description:
1 = 800 rpm
2 = 1500 rpm
3 = 3600 rpm
4 = 5000 rpm
CON-P = on / off injectors STOP
You can use this calculator to know how many hz is in 1 RPM, this is for ensure the correct speed needed.
Conversion from Hz to RPM:
800 rpm = 13.33hz
1500 rpm = 25hz
3600 rpm = 60hz
5000 rpm = 83.33hz
Step 1: Part List
PART LIST
- ARDUINO UNO
- L298N DC Stepper Motor Driver Module Dual H Bridge
- Tact Tactile Push Button Momentary (x6)
- Light Emitting LED Diode (x7)
- Electric Box (it could be any other Project box)
MISC
- 4 injector EV1 Plugs (from an old VW hardness in this case)
- Plastic Electrical Box (or any other project box)
- Wiring
- Shrink Tubes
- 12v AC Adapter at least 5amp for injector operation (It could be a Computer PSU or car battery)
Tools
- Screw Drivers
- Plyers
- Drill
Step 2: SChematic
Step 3: THE CODE
//============================================================================================<p>//VARIABLES GLOBALES y CONSTANTES
const int b_800rpm = 8;
const int b_1500rpm = 7;
const int b_3600rpm = 10;
const int b_5000rpm = 11;
const int b_salir = 4;
const int b_consflujo = 3; //boton flujo constante al presionar
const int LEDReady = 13; //Indicador Ready
const int LedRPM = 6; //Indicador RPM en funcionamiento
const int LED800rpm = 5; //Indicador 800rpm
const int LED1500rpm = 2; //Indicador 1500rpm
const int LED3600rpm = 12; //Indicador 3600rpm
const int LED5000rpm = A0; //Indicador 5000rpm
const int inject1 = 9; //pin de injeccion pin9</p><p>//estas variables guardan el flash pattern
int inject_State = LOW; // estado utilizado para setear el pin
unsigned long previousMillis = 0; // sera guardara la ultima vez que el pin injeccion fue actualizado</p><p>//Estados de pin Entradas (botones)
int eb_800rpm;
int eb_1500rpm;
int eb_3600rpm;
int eb_5000rpm;
//int eb_usonido;
int eb_salir;
int eb_consflujo;</p><p>//============================================================================================
//SETUP
void setup() {
//entradas
pinMode (b_800rpm, INPUT);
pinMode (b_1500rpm, INPUT);
pinMode (b_3600rpm, INPUT);
pinMode (b_5000rpm, INPUT);
pinMode (b_salir, INPUT);
pinMode (b_consflujo, INPUT);
//pinMode (b_usonido, INPUT);</p><p> //Salidas
pinMode (LEDReady, OUTPUT);
pinMode (LedRPM, OUTPUT);
pinMode (inject1, OUTPUT);
pinMode (LED800rpm, OUTPUT);
pinMode (LED1500rpm, OUTPUT);
pinMode (LED3600rpm, OUTPUT);
pinMode (LED5000rpm, OUTPUT);</p><p> // analogReference(INTERNAL);
Serial.begin(9600);
digitalWrite (LEDReady, HIGH);
}</p><p>//============================================================================================
//VOID LOOP
void loop() {</p><p> eb_800rpm = digitalRead(b_800rpm);
eb_1500rpm = digitalRead(b_1500rpm);
eb_3600rpm = digitalRead(b_3600rpm);
eb_5000rpm = digitalRead(b_5000rpm);
//eb_usonido = digitalRead(b_usonido);
eb_salir = digitalRead(b_salir);
eb_consflujo = digitalRead(b_consflujo);</p><p>//SELECCION DE SUB RUTINAS - FUNCIONES DE PULSOS</p><p> //activa a 800rpm
if (eb_800rpm == HIGH)
Pulse_800rpm();
//activa a 1500rpm
if (eb_1500rpm == HIGH)
Pulse_1500rpm ();
//activa a 3600rpm
if (eb_3600rpm == HIGH)
Pulse_3600rpm ();
}</p><p> //activa a 5000rpm
if (eb_5000rpm == HIGH)
Pulse_5000rpm ();
}</p><p> //activa inject1 mientras este presionado luego apaga al soltar el boton
if (eb_consflujo == HIGH)
digitalWrite(inject1, HIGH);
else
digitalWrite(inject1, LOW);
/* //activa el limpiador ultrasonido
if (eb_usonido == HIGH)
u_sonido ();
} //cierra el void loop()</p><p>//============================================================================================
//SUB RUTINAS
//============================================================================================</p><p>void Pulse_800rpm() {
afuera:
delay(300);
for (; ;) { //800RPM aproximadamente Modo IDLE
digitalWrite(LedRPM, HIGH);
digitalWrite(LED800rpm, HIGH);
long OnTime = 76; // tiempo encendido en milisegundos
long OffTime = 61; // tiempo apagado en milisegundos</p><p> // verifica si cambio el tiempo del estado del pin de injeccion
unsigned long currentMillis = millis();</p><p> if ((inject_State == HIGH) && (currentMillis - previousMillis >= OnTime))
inject_State = LOW; // lo apaga
previousMillis = currentMillis; // Recuerda el tiempo
digitalWrite(inject1, inject_State); // actualiza el Inject1 actual
else if ((inject_State == LOW) && (currentMillis - previousMillis >= OffTime))
inject_State = HIGH; // lo encuende
previousMillis = currentMillis; // Rercuerda el tiempo
}</p><p> else if (eb_salir == HIGH) {
digitalWrite(LedRPM, LOW); //apaga el led RPM
digitalWrite(LED800rpm, LOW);
break;
}</p><p> }</p><p>}</p><p>void Pulse_1500rpm() {
afuera:
delay(300);
for (; ;) { //1500RPM
digitalWrite(LED1500rpm, HIGH);
long OnTime = 40; // tiempo encendido en milisegundos
long OffTime = 32; // tiempo apagado en milisegundos</p><p> // verifica si cambio el tiempo del estado del pin de injeccion
digitalWrite(LED1500rpm, LOW);
break;
}</p><p> }</p><p>}</p><p>void Pulse_3600rpm() {
afuera:
delay(300);
for (; ;) { //3600RPM
digitalWrite(LED3600rpm, HIGH);
long OnTime = 16.6; // tiempo encendido en milisegundos
long OffTime = 13.28; // tiempo apagado en milisegundos</p><p> // verifica si cambio el tiempo del estado del pin de injeccion
digitalWrite(LED3600rpm, LOW);
break;
}</p><p> }</p><p>}</p><p>void Pulse_5000rpm() {
afuera:
delay(300);
for (; ;) { //5000RPM
digitalWrite(LED5000rpm, HIGH);
long OnTime = 10.52; // tiempo encendido en milisegundos
long OffTime = 8.4; // tiempo apagado en milisegundos</p><p> // verifica si cambio el tiempo del estado del pin de injeccion
digitalWrite(LED5000rpm, LOW);
break;
}</p><p> }</p><p>}</p><p>/*Esta parte sera dejada para programar correctamente el tiempo de encendido ya pagado
de la limpiadora ultra sonido*</p><p>*
void u_sonido() {
afuera:
delay(300);
digitalWrite(LedRPM, HIGH); //indicador RPM
digitalWrite(ledusonido, HIGH); //enciende led indicador ultra sonido
eb_salir = digitalRead(b_salir); //Estado boton salir
unsigned long time = millis();
int toggle = 1;
digitalWrite(d_usonido, LOW); //enciende la ultrasonido
// delay (10);
// digitalWrite(d_usonido, LOW); //apaga el estado de d_usonido para dejar listo para otro proceso
if(millis()-time > 1000) //Has one second passed?
toggle = !toggle; //If so not toggle
digitalWrite(d_usonido, toggle); //toggle usonido
time = millis(); //and reset time.
digitalWrite(ledusonido, LOW); //apaga el indicador de limpiadora ultrasonido
break;
}</p><p> }</p><p>}
*/</p>
Step 4: The Assembly
At this point i had the proyect done like a year ago and i decide to publish it now, so i didnt took photo for the process but as you can see not hard to do something like this following the Schematics. On the other Hands works very well, i had a lot of injectors cleaned with a home made test bank.
