Introduction: Fun Hairstyles
I have pretty long hair and it is always super fun to do stuff with it! Here are just a few of some pretty cool hairstyles that I use on a regular basis.
The supplies you need depends on the hairstyle, but if you were to do them all you would need,
Brush
Hair Ties
Alligator Clip
Hairspray
Bobby pins
Step 1: Half Up Half Down W/ Clip
So for this one, it is super easy all you need to do is to section the hair into two pieces (one on top the other on the bottom) smooth out the hair, and secure it with a hair tie, then put the clip in. You don't have to do this but I smoothed out the top with hairspray to keep the flyaways down. That's it!
Step 2: Bubble Braid
For this one, you want to start with a sleek high ponytail, then a few inches down you add another elastic and continue until you run out of hair. Once all of the elastics are put in use your fingers to tease and pull at each section, which will create bubbles. And as the last step I pull some hair out to frame my face but that is completely optional.
Step 3: Messy Bun
First, put your hair in a high ponytail, but don't tie the elastic, just yet! put your hair through once or twice depending on the thickness, then for the second or third time, stop when your hair is about halfway through the elastic. Use the extra hair to wrap around the base of the bun, then secure it in place with bobby pins. That's it!
Step 4: Braided Ponytail
To start take two sections of hair near the front, one on either side and braid them stopping a little more than halfway. Now put your hair (braids included) into a high ponytail. That's it!
Step 5: Your Done!
These are some of my favorite hairstyles and I hope that they help you in your search food good ones!
