Introduction: Fun Idea on Making a Seed Bead Waterwheel Necklace
Today I would like to introduce you a seed bead necklace idea. How to make a lovely waterwheel necklace with multi-colored and –sized seed beads? I will explain you the idea in the following tutorial.
Step 1: Necessities for the Seed Beaded Waterwheel Necklace
4mm inside color glass seed beads
4mm opaque color glass seed beads
6mm natural Mashan jade beads
8mm brass jump rings
Cross chain
Silver jump ring
Eye pins
Round nose plier
Flat nose plier
Wire cutter
Scissors
Step 2: Make Seed Bead Waterwheel
1st, slide acrylic seed beads, glass seed beads and jade bead onto eye pin;
2nd, bend down the pin into 90 degrees;
3rd, loop the pin with round nose;
4th, prepare 7 such seed bead links;
5th, slide bead links onto one jump ring;
6th, assemble the bead links with another jump ring.
Step 3: Finish Waterwheel Necklace
1st, cut a 50cm length of chain;
2nd, thread it through your finished waterwheel;
3rd, attach lobster claw onto left end;
4th, attach jump ring onto right end.
Step 4: Final Look
Tada! You have done this lovely waterwheel necklace. Hope this chic seed bead necklace brings you a touch of glamour and loveliness.
