Introduction: Fun With Liquids for Kids
Hi All,
I wanted to introduce liquid density concept for my son and have fun
I am going to share how to build Ocean in a bottle and Oil Timer, using everyday items, found at home
Kids can do this by themselves with little Adult supervision and have fun
Step 1: Oil Timer
Material Needed
- 2 Plastic bottles ( small sized, cola bottles)
- 1 Straw or thin pipe
- Super glue
- Water ( Distilled water prefered )
- Blue Water color
- Vegetable oil
How to make ?
- Super glue two bottle caps and puncture/drill holes large enough for the pipe to pass
- The pipes must fit tight, if you feel they are loose use can use super glue to hold them
- The pipe height is adjusted as per the image ( It should not be at same height, keep 0.5 inch gap)
- Add water to one of the bottles and add (water based) blue color in it, till you are happy with the shade
- Close the cap while applying super glue
- FIll Oil into another bottle, till the rim edge
- Now with a swift action invert the bottle with water and close the cap
Video
Link may not work on app
Step 2: Ocean in a Bottle
Material Needed
- 1 Plastic bottles
- Super glue
- Blue Water color
- Vegetable oil
How to make ?
- Add water to the bottle ( half filled)
- Add blue color till you are happy with shade
- Add Oil till the rim edge, removing as much as air
- Super glue the bottle cap to the bottle while closing
Video
Step 3: Tips
I noticed after a day playing with them, the clarity in the oil went bad. This was because of impurities in water that got emulsified in oil.Let the bottles sit for a day, all dirt / impurities settle as a small layer just above water and below oil
Carefully remove oil and then water using a straw or pipe and fill them up again
