Function Generator
Intro: Function Generator
Greetings, everyone!
Are you in search of an affordable solution for a function generator? If purchasing one isn't your preference, you can embark on this exciting tutorial to create your own. A function generator proves to be an essential tool for numerous projects. In my case, I utilized it to construct wireless power transmission modules. Through extensive online research, I discovered a remarkable and remarkably simple method to build one.
Central to this project is the versatile IC ICL8038, which offers an output of sine, saw, and square waves within a frequency range spanning from 150Hz to 150KHz.
Your support and votes for Remix 2.0 would be greatly appreciated.
Let's commence our journey to build this amazing function generator together!
STEP 1: Material and Components Required
Let's browse what we all need.
1. 3x10K Potentiometer.
2. 1x1K variable resistor(I've used a trimpot one) .
3. 1x4.7K variable resistor .
4. IC ICL8038.
5. 1xTransistor 2N1613.
6. 1xDC Jack.
7. Wire Terminal.
8. 1x 4 terminal rotary switch.(or any sort of switch for tuning, due to lack of availability I've use dip switches)
9. 15k and 2M Resistor.
STEP 2: THE CIRCUIT
Presenting the circuit diagram for our function generator project. Follow the provided circuit layout, but instead of the 1M resistor, substitute it with a 2M resistor. If you prefer, you can even create a PCB (Printed Circuit Board) for this circuit. If you require the Eagle file for this project, kindly leave a comment expressing your interest, and I will gladly upload it for you.
STEP 3: Power Up
Power up your function generator, and it's ready to be deployed.
STEP 4: Updates
*********4/10/16*********
Added github link to cad files
11 Comments
geller6980 8 years ago
rossak 7 years ago
It generates the functions.
_Boltz_ 8 years ago
depends............. the same answer........... have a look to the datasheet....... of your full part number i.e ICL8038"XX" (Without inverted commas)
SCS Creation 8 years ago
wat is the output voltage
_Boltz_ 8 years ago
rahul540 8 years ago
_Boltz_ 8 years ago
Ferrerow 8 years ago
How can i make the frequency waves ranging from 0Hz to 150KHz?
_Boltz_ 8 years ago
you can use a microcontroller for that..... and two transistors........ and some potentiometers........ you have to make those blink programs..... and have to use potentiometers to tune the frequency........
