Introduction: Functional Spiderman Mask From No Way Home With Moving Lens - Gold and Black Mini Version
Hey Makers, Love to see you here again! In my previous instructable i made Miles Morales Mask with moving lenses, Since then in my YouTube video many asked me to make NO WAY HOME VERSION so i made Moving lens version of no way home which i will be sharing you in this instructable
Important thing here being my previous version was very big hence many could not make that, But this is small and can be made very easily.
I have given free templates for this project
Step 1: Supplies and Template
Download Free Template for this Project HERE , This template can be hand drawn of print in sheet of paper
Once you have your template you can gather these materials
- Cover from your old book
- Scissors
- Paper glue
- Black fabric paint
- Tissue paper
- white paper glue and paint brush
- Some threads and gold paint
- Black paper
- Fish wire as alternative you can use plane thread
Step 2: Making Face Shell
It is good to call face shell instead of face mask, Hence i will be using this word hereafter!
Once you have template glue it on bind cover of your notebook and allow some time to dry
After you have your dry template, Cut along the mark using scissors
End of the step you will have Pieces that needs to be glued
3 pieces from one side will make half shell and rest 3 forms other half
Now we will see how to make half shell
Fold pieces as shown in images and later using hot glue couple them
Process is very simple and you will enjoy this step
After you have half of the shell do the same process for other half
Glue these halves to make it full!
Step 3: Hardening the Shell
The shell which we made will be fragile and wont be capable to handle minor shocks hence we need to harden it
To harden mix your normal white paper glue with water, Then cut stripes of tissue and apply all over the shell
End of the process you will have wet shell, Allow long hours to dry completely
Step 4: Working on the Shell
After your shell is dry it needs to be painted, use fabric paint or spray paint to get this job done
To make sides of the eyes for shell i traced inner measurements of eyes on plane sheet of paper
Do the same for other side eyes too
Cut the same on black piece of board or on thick black color paper
Glue it to the eye part, Meanwhile we can proceed with making golden lines
Step 5: Golden Lines to Shell
Spiderman mask is nothing without spider web, To make this i made use of gold paint that was painted on woolen thread
Use guiding lines that was pre drawn on shell that resembles spider on the shell
It consumes some of your time, But the way you do this determines overall looks at the end, Hence work with patience
Step 6: Adding Eyes
These work similar to the way as scissors does, One end is fixed other is free
So we make size measurements using white sheet, later when everything is perfect cut it on black sheet
Install it on inner shell, use toothpicks if necessary to make this firm inside shell
Step 7: Finishing
I made use of fish wire that is connect to lower lids of the eyes, if we do this blankly we need to close/open our eyes manually
Hence ELASTIC BAND is the life saver here! Cut bands and glue it to bottom eyelids while to the same glue fish wire also
To get the work done effectively we need string holders which is made by rolling paper tubes and cutting them
This was glued inside face shell as you can see in images
Step 8: Working
This works when you pull the fish wire
If you just pull the wire in downward direction eyes starts moving you can increase or decrease depending on how hard you pull!
For Working Video of this project consider checking HERE
