Introduction: Fused CFL As Replacement for Electronic Choke (Ballast) for TubeLight
How to use unused CFL (or damaged) in place of ballast in tubelight
Step 1: About the Project
Hi,
Today i m going to tell about a very interesting project. This project helps in saving environment because it is a type of recycling damage CFL.
You also Save Money
Step 2: Ingredients
You require the following things
- Damaged CFL (Tube Fused but Circuit OK)
- Normal Tubelight Set
- Soldering Iron
- Wires
Step 3: Dismantle CFL
First safely open CFL and remove circuit board from it (Use Ecofriendly Way to dispose)
Now cut the attached wires
- From Supply (2 Wires)
- From tubes (4 Wires 2+2)
Step 4: Attach in Place of Ballast of Tubelight Set
Now attach this circuit according to figure
1. Attach 2 wires from Supply (220V)
2. Attach 4 Wires to Tube Light End (Use Tube light Hoder) 2+2 Each side
*No need of Starter or anything
Step 5: Final Setup
Now put the circuit in an insulated manner to the tube light set and fit it on the wall like normal tube light set;
Enjoy !!!
6 Comments
5 years ago
This would work with 22w circular fluorescent
7 years ago on Introduction
i already make that project. But use 18W/20w florusent bulbonly becase the circuit power cappacity is 14W/ 20W. Brightness is good
8 years ago on Introduction
What about using 110V instead of 220V? I have about 12 110V tube lights that are either out or don't work in cold weather. Would love to replace the ballasts with CFL circuit boards.
An electronic choke for tubes are usually of much better quality than ccfl ballasts, my $10 (36W/1.2m) tube+choke+casing lasts for 5 years already(one electrolytic cap changed on 3rd year), and $5 ccfls(20W/E14) after a couple of years have dried insulation on toroidal transformer which comes off as a powder and dead capacitors.
The wattage rating of the CFL should be equal to or higher than that of the tube otherwise it will probably overheat & die quickly.
8 years ago
Good idea!!! Best way to RECYCLE CFLs
