GARAGE STORAGE SOLUTION
Intro: GARAGE STORAGE SOLUTION
CEILING TOOL STORAGE, USING HINGED PANELS AND PULLY TO SECURE TOOLS OUT OF THE WAY IN CEILING.
STEP 1: Step 1
Used 1/2" ply panel to form racking, hinged to ceiling set off from wall about 4inches ,this allows further storage behind and prevents board hitting wall.I used piano hinges for strength and they also help prevent warping and twisting of panels.
STEP 2: Step 2
Used nylon reinforced cord , from a boating shop as it has high breaking strain.This is threaded up to small pulleys, again from boat suppliers,mounted in ceilind timbers, I needed two but will depend on roof structure.The cord travels down thru self locking boat cleats , not sure if thats the correct name.
The cord can then be used to raise or lower panels, I lift mine to ceiling as it's fairly low but can be done purely with cord if needed.
STEP 3: Step 3
The panels can then be set out to accomodate your tools, simple screws hold a variety of tools but I also used some metal clips, from the garage roof tiles I had left over, to mount tool boxes, also small shallow box formed from ply at base of each panel for odds and ends.
STEP 4: Finally
The previous pic shows a heavy tool rack which is strenghthened with timber along the edges to prevent it sagging when lifted to ceiling, only found this required when very heavy tools stored.Also used old cutlery rack from dishwasher to store smaller tools.
40 Comments
Starsword7 8 years ago
Great idea!
If you had the hing a foot or two from the wall you could have shelves behind it, so this would provide additional storage (maybe for less used items)
ChristopherJames 8 years ago
Now if this were me and my garage, I would forget that I'd have things in storage in the ceiling after a while! Better to have things in plain sight where I won't forget that I've put them!
EricColbert 9 years ago
For my storage shed, I maximize space by fully utilizing the walls. I build racks, shelves, and closed cabinetry to store all my items neat and tidily. I do not create any storage using the ceiling space because I have always thought it will not be as sturdy and durable enough to withstand much weight, and especially tools that I have in my garage. However, this pull-out hinged panels idea is still worth a try.
VTsikolia 9 years ago
Hello, Thank you for Simple and good idea.
anasdad 10 years ago
Excellent job!
RocKin40G 11 years ago
MarkSindone 11 years ago
Narlo11 11 years ago
Blacksedan47 12 years ago
reddnekk 12 years ago
So all you fellows with ideas for making a two-car shop more efficient and friendly, please--Keep IT UP!!
bluedragonlotus 13 years ago
chefguru 13 years ago
If you designed a bench to fold up, and still had the tool racks spaced 4 inches out from the wall, then you could access your tools with the bench folded up against the wall in case you only needed a tool, but didn't need the whole bench.
I have a 2 car garage, but if I actually want to park 2 cars in it (or 1 car, and my 3 motorcycles), then I don't really have room for a work bench. However, this might be a really good idea for having the option of actually having a work bench that I would be able to use with hiding tool storage.
Thanks, good idea.
acardboardllama 13 years ago
IdahoDavid 17 years ago
caarntedd 13 years ago
At the moment the only form of transport inside is my motorcycle. there may also be a skateboard in one of the piles.
xcoastie 16 years ago
leevonk 17 years ago
jeffeb3 13 years ago
radiorental 17 years ago
neorazz 14 years ago
(when i do this i'll post my instructable )
hinging look at attic retractable stair hinges
ease of use needs spring system to help with retracting
latching twist handle in center of panel with offset pull rods that would lock panel in place and act as hinge pins if these were on both ends the panel could open front or back of work area if items on panel were mounted appropriately
or just reverse the hinge so the panel would open up behind the walking area of your work area then its never in the way of your project
