Introduction: GLAM Autumn/Fall Makeup Look
So its getting close to the festive holidays and it is time to get glam all of the time. Here is a quick and easy look that you can do.
Step 1:
First you want to fill in and shape your brows. This is a great way to makeup your look put together. Not doing your brows will leave them looking messy.
Step 2:
For the eyes you first want to apply a skin toned shadow all over the lid and up into the brow.
Then with a yellow mustard colour blend this out into the crease making sure it is blended.
To deepen up the crease apply a brown shadow in the crease also keeping a little lower than the last shadow. It doesn't have to be perfect as we will clean up the lid next.
Step 3:
Now you want to clean up the lid. You can use a eye primer or concealer. You want to get a flat brush and apply this onto the lid up into where you want it to be on the crease.
Then with a pink/plum shimmer shadow apply this where you applied the concealer.
Going back in with the brown shadow you want to blend this on the outer corner and lightly on the crease.
Step 4:
To finish on the upper lid apply a wing to your eye and mascara to the top lashes for now and apply false lashes also.
Step 5:
For the face you first want to prime it. Then with your foundation apply this all over the face making sure to take it down your neck and ears.
Step 6:
With concealer you want to apply this to the under eyes, chin, nose and forehead and blend it out. To set this into place apply a loose setting powder over the top of the concealer and this will prevent creasing.
Step 7:
Now to shape the face you want to apply a contour powder on the hollows of the cheeks, jawline, hair liner and nose.
Step 8:
To add a bit of colour to your cheeks apply a pink/ red blush to the apples of the cheeks.
Step 9:
Back to the eyes. With the mustard yellow shadow apply this on the lower lash line and the same with the brown shadow keeping that a little closer to the lash line.
Step 10:
To finish of the full look apply a pinky brown liquid lipstick to your lips.
