Introduction: GPS Cup Holder Mount
A GPS mount made from PVC pipe fittings to fit the cup holder in your car. The prices of GPS units have drastically come down this year. So I bought a Tom Tom One 125 from Fry's Electronics. Next thing I learned, in California, its illegal to mount one on the windshield!
After searching the Web, I found a type of mount that can be used in the cup holder of your car. They cost about $20 buck for such a piece of plastic. Thats when I decided to try and make my own.
This is an ideal project for those with tools, as most Makers do anyway. With just a few tools and a bench, you can fix and make things that can save you money.
Step 1: PVC Pipe Components
Three inch PVC pipe is a little wobbly in the holder, however, a 3 inch pipe cap is just the right diameter.
Parts you will need:
1 piece of 3 inch PVC pipe, 2-7/8 inch long.
Two 3 inch PVC pipe caps.
One 1/4-20 flat head bolt about 1-1/2 long.
One 1/4 inch nut and washer.
Epoxy cement
3 inch disc, 3/8 thick made from plywood, plastic other material. The self-adhesive pad that comes with the GPS is attached to this disc. If you can find a PVC pipe cap that is flat on top, the disc is not needed. Mine was curved and needed a flat surface.
Tools:
Hack saw to cut the pipe.
3-1/8 inch hole saw.
1/4-20 tap and #21 drill bit.
Countersink bit.
file to remove flash and sharp edges or sandpaper.
Drill press, if you own one.
Step 2: Attach the Pad
A self-adhesive pad comes with the GPS unit. It is used to mount the unit to a spot on the cars dash with the GPS suction cup. Instead, we will mount the pad to a disc that is attached to the cup holder mount.
Make the disc using a 3-1/8 inch hole saw. The material can be plywood, thick plastic or in my case I had some phenolic material scrap from work. If you use plywood, seal it with paint or clear coat. This will help with bonding to the GPS self-stick mount.
Step 3: Tap Hole for Disc
Tap a 1/4 -20 hole on the top of the PVC cap.
Counter sink a hole on the disc in the middle and slip in the flat head bolt. Be sure the counter sinked hole is deep enough so as not to interfere with attaching the self-adhesive pad.
Use a little 5 minute epoxy to secure in the bolt to the disc. It will keep it from loosing up over time.
If you have a drill press, use it to start the tapping of the hole. This will keep the tapped hole perfectly straight. I just chuck up the tap and lower into the hole and twist it by hand.
Step 4: Screw in the Disc
After the flat-head bolt is mounted to the disc and the epoxy is cured, screw in the disc to the PVC cap.
Step 5: Bolt the Inside
Use a 1/4-20 nut and washer to secure the bolt and disc to the PVC pipe cap. Threading the cap makes a tighter assembly.
Step 6: Assemble
Put together with the short piece of PVC pipe and the bottom cap. Don't glue it together, just press fit.
You can even paint it to match you cars interior. I'm planing on giving it a flat black paint job.
Step 7: Stick on the GPS
Stick on the GPS with its suction cup to the top of your new holder. It is now ready to use.
Step 8: Travel Tip
You may be tempted to glue it together. Don't. When traveling through Airport Security, you may be asked to show what you got. To X-ray, it looks like a pipe bomb with a GPS trigger device! You can twist off the bottom and show there is nothing inside.
Craftsman Workshop of the Future Contest
36 Comments
8 years ago
i like this but im going to put a taller pipe to get it to dash pad level and give me room to hit my radio controls and not make (any more) holes in my dash
11 years ago on Introduction
Not to be a wet blanket, but: I don't think it's safe to be looking down at your cup holder to check your GPS... The whole idea of having it at dash level (even if it's not attached to your windshield) is that your eyes stay at traffic level.
12 years ago on Introduction
Finished product.
$8 total. (didn't have any spare parts laying around)
Many thanks for the great idea. Went with Velcro instead of the mounting system I linked before.
Ps. My brother in-law is now making his as well.
13 years ago on Introduction
I'm watching the inventor of the "GPS Pal" describe this very thing on "Pitch Men" on Discovery Channel. I can't believe he got a patent.
Reply 12 years ago on Introduction
I saw the "GPS Pal". 20 bucks for a piece of plastic!
One million thank you's for this one. I have been searching for a way to mount my Archos 5 in the car for days. With some slight modification on the pad, i can get this to work 100%. I will be mounting "Pro Clip's Move Clip" in place of the GPS suction to a wedge shaped piece of wood. www.proclipusa.com/brodit-device-holder/proclip-move-clip/move-clip-kit-(1-male-and-1-female-plate)-213093-13975.aspx
This is going to save me a lot of money in the end.
Thanks again.
Send a photo to us after you make it. I took mine through airport inspection to West Virgina with no problem. Just leave it dis-assembled so it don't look like a b0mb. If its loose in a cup holder, you can put a sock on it.
Great idea! Did something similar to this using a "tall" aluminum can (Green Tea, as I recall) and filled with lead shot and beach sand for stability. Glued a mounting disk to the can top for the suction mount, and it doesn't move in the console cup holders. Also has the benefit that it raises it up a bit more conveniently (although still not quite the HUD it was intended to be). All that, and it's so heavy, you could defend yourself with it!
12 years ago on Step 8
I like this idea, I'll be making one up for myself this weekend. Thanks fro the info.
Reply 12 years ago on Step 8
If you do, send a photo!
great idea! i'm gonna do this for sure!
Reply 13 years ago on Introduction
why getting so trouble, go to www.gpscushion.cn and find a GPS cushion(dash mount)!
I know i sound stupid, bit how do i load an instructable, i cant find out how
Go to the top and click on "Submit" Read the instructions. You can also do a slide show by loading just photos.
awesome idea! I have yet to get a suction cup mount for my GPS -- all I have at the moment is the one that came with my GPS that you permanently mount to your vehicle. Can't stand permanently affixing something. This sounds like an excellent solution. Also -- the way my dad gets around the CA law is he mounts it on the driver's side window. Not a big fan as I have to move my eyes too far from the road. Thankfully I live in SC where its legal to ride your motorcycle without a helmet...
Vehicle Code 26708 also included the side window.here
well then... that's useful. thanks
This will be handy when Geocaching! Check out geocaching.com Thanks
Adding some sand/salt/rocks/whatever to the PVC will let you use quite a lot more devices with this. I'm thinking that this might be very useful indeed... A couple of quick mods, and I may have a very nice solution. Kudos.
Great idea. I made one in 10 minutes and the only thing i changed was I shaped the bottom of the disc to match the curve of the top cap and I added a ziplock bag of sand to give it some weight to hold it in the cup holder. It doesn't shake at all. My gps has a taller mount that would move when on a bumpy road. (I live in upstate new york)
