Introduction: GREEN IDEAS!
Spring, ST. Patricks day, the color green I thought about doing a green instructables
from green to green, to drink one to play with and others just green, so come on lets go make your day Green!
Step 1: ST. Patricks 4 Leaf Clover Hair Clip
You will need:
craft glue
Green felt
scissors
hair clip
marker
First cut out 4 clovers and one small strip for a stem
then a small circle enough to fit the end of the clovers on to glue.
Glue the stem under the circle then glue the hair clip on.
craft glue
Green felt
scissors
hair clip
marker
Step 2: Organic Green Playdough
How to make green play dough you will need:
1 cup flour
1/2 cup salt
1 cup water
2 tablespoons oil
2 tablespoons cream of tartar
beet,spinach,and carrot juice
Mix flour, salt and oil, and slowly add water. Cook over medium heat, stirring until
dough becomes stiff. Turn out onto wax paper and let it cool. Knead the playdough with
your hands until of proper consistency. Use as is, or divide into balls and add a few drops
of the vegetables juices to make green.
(found online not my own recipe.)
1 cup flour
1/2 cup salt
1 cup water
2 tablespoons oil
Step 3: Leprechaun Dog Hat
O.K. since St. patricks day is coming up I decided to make my sisters dog a leprechaun hat.
Now the things you will need are:
felt- 2 Green,Black,Yellow,
craft glue
ruler
scissors
marker
Use green felt and cut 7 inches high & 6 inches wide.
Then cut a green square 5 3/4 inches wide & 6 inches long.
Take 7 in to 6 in green felt you cut out earlyer and roll it up to make a tube and gule.
Then take your 5 3/4 inch to 6 inch felt green and cut it to make a circle then in the center cut a circle the size of the tube circle and glue it to the circle tube.
Next take your black felt and cut 11 inches then rap it around the the tube and glue
Now you will take your yellow felt and cut 1 inch by 1 inch then cut in the middle a square and glue the your yellow buckle you just made to the black piece.
Almost done cut from your green felt a 4 inch to 4 inch then put the piece on top of your hat and glue then after its done drying
cut around it.
One more adjustment now use entheir elastic string or a small strip of green felt about 8 inches long to how wide you want it to be but try not to make it really thin. Then glue it on the bottom side of the hat and your done.
craft glue
ruler
scissors
marker
cut around it.
Step 4: Green Tea
Whats better in the moring than a cup of green tea
you will need:
measuring cup
loose green tea leaves
teapot
water
Where to get loose green tea leaves:
you can get them at Whole Foods, Trader Joes or local Asian supermarkets
How to make it:
O.k. the water it's best to use spring water or filtered water. Distilled water
ruins the integrity of the green leaves plus it takes away the health benefits.
Now that you have your teapot and a portion of loose green leaves per milliliters of water make a use of a measuring cup
when you put the and green tea leaves in the teapot let it boil reducing the temperature of 85 degrees celsius before you drop the leaves in let the leaves boil for a minute, Well you are done so enjoy your green tea.
(recipie and photo aren't mine)
you will need:
measuring cup
teapot
water
How to make it:
Step 5: Green Paint
This is pretty easy to make all need you is;
yellow and blue paint
Then mix them togther and it will make green!
Step 6: Green Dye From Coneflower
Now snice I was make green things I thought make green dye,so that every thing will be green
now go outside and see if you have coneflower if so
Blossoms should be in full bloom, berries ripe and nuts mature. Remember, never gather more than 2/3 of a stand of anything in the wild when gathering plant stuff for dye Chop plant material into small pieces and place in a pot. Double the amount of water to plant material. Bring to a boil, then simmer for about an hour (for plant dyes) 4 parts cold water to 1 part vinegar
I think it works best with fabric.
(not my own recipie found online.)
Step 7:
Things you"ll Need:
6 oz. packagelime Jell-o
14 oz. can sweetened condensed milk
1/2 teaspoon almond extract
7 oz. shredded coconut
mixing bowl
wooden spoon
teaspoon
small plate
baking sheet
wax paper
1: Measure 1/3 cup of coconut then set aside for later use. Empty a full package of powedered jell-o into the mixing bowl.
Pour the sweetened condensed milk over the Jell-o powder and add the almond extract. stir the concoction with a wooden spoon
until the mixture is smooth and well combined.
mixing bowl
wooden spoon
teaspoon
small plate
baking sheet
wax paper
Step 8: Green Goo
Alright green slime goo! now thats what I call gross
lets get making
First off you will need:
White craft glue
2 paper cup
green food coloring
borax
spoon
measuring cup
plastic bag Instructions:
(got this online)
lets get making
White craft glue
2 paper cup
green food coloring
borax
spoon
measuring cup
- 3
Add three to four drops of food color to the glue and water mixture. Use traditional slime green or get creative and use blue, red, yellow or a combination of colors. Mix the food color into the glue and water mixture thoroughly with a spoon.
- 4
Measure 1 tablespoon of the water and borax solution and add to the cup with the glue, water and food color mixture. Stir the ingredients with a spoon to thoroughly combine.
- 5
Allow the mixture to sit for at least 30 seconds. Remove the slime from the excess liquid in the cup.
(got this online)
