Introduction: GSM Alarm System for Leaks Without Arduino
Hello.
- In today's video we will do just such an alarm about the water leakage.
- That will alert you with an audible signal Itself will block the water and call you on the phone.
- You can also manually control the valves.
The scheme is simple and without AVR end Arduino
Detailed assembly and demonstration work can be seen on the video.
Step 1: We Need
- One or two valves (valve with three terminals)
- Old phone (I Siemens CX75)
- A transistor IRLB8721
- Resistor 2M
- Relay 5 volts ( TRSB- 5VDC-SB-L15 or BT-5S 5V )
- Buzzer HCM1206X
- Diode SF18 or HER107 or FR104
- Two buttons
- Suitable housing
- Four batteries
The scheme is very simple
Step 2: The Scheme Is Very Simple
Step 3: Attach the Scheme.
Step 4: Insert the Wires Into the Body
Step 5: Glue and Solder
Step 6: On Your Phone, Set Up a Quick Call to Your Number on the Button 9
Step 7: Phone Upgrade
- remove the keyboard
- disassemble
- cut away the film on button 9
- solder wire
- cut off button 9
- install the keyboard back
Step 8: Testing
Contact Sensor must be placed on the floor in the bathroom or in the kitchen.
Thank you for attention.
