Introduction: GSSE Carousel
by Kalyn Grice, Justin Canfield, and Emalyn San Miguel
Step 1: Prepare the Base
-Cut out two 12 inch wide wooden bases with a jigsaw
-Sand each wooden base
-Cut out 1 inch wide circle into only one of the bases
-Spray paint (if preferred)
Step 2: Prepare the Poles
-Cut six 1/4" diameter poles
-Wound and hot glue yarn around the poles or decorate as desired
-With gorilla glue, attach the poles around the base with the hole cut out. Make sure the poles are sturdy enough to hold the roof.
Step 3: Roof
-cut out another 12 inch circle
-decorate as desired
Step 4: Dominoes
-hot glue dominoes around the circumference of the base without the hole. This is so that when the two bases are connected, there will be a space for the arduino
-Make sure to leave a space without a domino around the circumference for wires
Step 5: Animals
-download your preferred 3D animals onto a flashdrive
-3D print six animals in your preferred color
Step 6: PVC Pipe and Spindles
-For the central point of the carousel, cut about a 1 1/2" of PVC pipe
-drill three 1/4" holes completely through both sides of the pipe, making six holes in all
-Cut three spindles, each nine inches and 1/4" in diameter and stick them through the holes of the PVC pipe
-hot glue the animals to the end of the spindles
Step 7: Arduino
-assemble and program an arduino to spin a servo
-attach a flat circle piece to the center of the servo
-hot glue a 1 inch cylindrical block to the flat circle piece of the servo
-hot glue the servo to the center of the base with the dominoes
Step 8: Assemble
-attach the base with the hole onto the base with the Arduino so that the cylindrical block is sticking out of the hole
-hot glue the animal piece onto the cylindrical block.
-attach the roof onto the poles
Step 9: Try It Out!
-turn on the Arduino and watch the animals spin like a real carousel!
