Introduction: GUITAR WALL HANGER
Many of us play different musical instrument and we are always bored to pack it back again in the instrument cover. My mom always scolds me for not putting things in right places so I came up with this instructables where we are going to make a guitar wall hanger which can be also use to hang SKATEBOARD also with few changes. Cost of the whole project is around 2$. It looks really cool when it is done.
Step 1: REQUIREMENTS
For this instructable you require,
Requirements
1-pvc pipe
2-pipe connectors
3-screws
Tools
1-Drill and bits
2- Hand saw
Requirements
1-pvc pipe
2-pipe connectors
3-screws
Tools
1-Drill and bits
2- Hand saw
Step 2: MEASUREMENT
Take measurements of your guitar (i.e width,length and broadness). Point out the main points where you are going to support your guitar . I have uploaded an image of my guitar where the points are highlighted and thus take the measurements at those points
Step 3: CUT THE PIPES
Cut the pipes as measured . Connect the pipe connectors and your done with your hangers
Drill holes through the pipe as showed in the image . Do it for all the t-shaped connectors as they will be fixed on the walls later.
Step 4: PUT SCREWS AND FIX IT ON THE WALL
Get the screws required from local hardware store. Drill holes wherever you want to hang you guitar. Connect you t-shaped connectors to the walls via screws and connect the other parts of the hanger. You can remove the vertical part of your hanger if not required as you can see in this case.
Step 5: HANG YOUR GUITAR AND DONE!!!
Hang your guitar on hangers and your done. You can also put your skateboards,
longboards, snowboards to the hangers by just cutting pipes as per your boards and connecting it to your T-shaped connectors.
