Introduction: Gadget Showdown:Windows 10 Tablet, Laptop, or Desktop?
When comes to personal computing on a modern Windows device, you have three choices: a Windows 10 tablet, laptop, or desktop. Each device has its pros and cons, and it will be up to you which one to pick in the long run.
So here's a quick breakdown of activities where each device fields an advantage:
Step 1: Value
When it comes to price tags, Windows 10 tablets have a clear advantage over their other Windows counterparts.
You could get a capable 8-inch Windows 10 tab for as little as $90, complete with a 1.44 GHz quad-core CPU, 2 gigs of RAM, and 32 gigs of internal memory. That's not a price tag that you can match with a laptop or desktop, even when you factor in other accessories like a Bluetooth mouse plus keyboard setup. If you're on a budget and need a Windows device, a Windows tablet is what you should get.
Step 2: Reading
Windows 10 tablets are the best platform for when you plan to do a lot of reading, whether for work or for pleasure.
Being able to conveniently hold a Windows tab up at a comfortable distance while scrolling with a flick of the wrist is a definite advantage. You can also position the tablet no matter what position you take, from standing up straight to lying in bed. That, and the vibrant color display along with the ability to easily zoom in or out make it easy to read documents, books, and magazines.
Step 3: Office Work
If you plan to work on office-related jobs that require a lot of typing and clicking around, you may find Windows laptops to be the better choice.
Physical keyboards tend to be more comfortable to work with over long hours. These keyboards are already bundled into laptops, which fold up into neat packages that can be easily stored and pulled out in short notice. That, and laptops can be easily set up on your lap as long as you have a place to sit on.
Step 4: Portability
If you want to use your device even while you're moving around, it's a toss-up between tablets and laptops.
The tiny size of Windows 10 tablets makes them ideal for tasks that only need one hand to accomplish. This, and they're the better choice if you're concerned about keeping weight down. Windows 10 laptops, on the other hand, are better when you need to actually input a lot of key information. They come bundled with everything you need to settle down to work – screen, trackpad, and keyboard to name a few.
Step 5: Customizability
If you want to mix and match parts for whatever purpose you have in mind, then you'll definitely want to get a Windows desktop computer.
Desktop computers tend to be rather large setups – something that makes it a lot easier to remove, replace, and upgrade the existing hardware. This makes it possible for you to select parts that you need, from budget-friendly setups composed of second-hand components to top-of-the-line rigs for high-end PC gaming.
Step 6: Longevity
While computer hardware last on average between 3 to 5 years, desktop computers as a whole tend to last longer than Windows-based tablets or laptops.
This is due to two factors. One, it's very easy to replace components that are failing – meaning you don't have to replace the entire system when one part fails or becomes obsolete. Two, the larger chassis of desktop computers allow for better internal cooling. Windows 10 tablets and laptops tend to trap a lot of heat when running resource-intensive programs. Desktops can be configured to improve airflow and heat conduction thanks to cooling mechanisms like extra fans or even water cooling systems.
Step 7:
Keep all these in mind, and you'll have a much easier time understanding which device will best suit your needs: A Windows 10 tablet, laptop, or desktop!
