Introduction: Game Show/Prize Wheel
Most of my projects have been fairly small or of a medium size. My sisters work was putting on a youth event and the theme was The Price is Right. So they asked me to make some of the price is right games included the big wheel. This is the biggest and probably the coolest thing I have ever made.
Step 1: Tools & Materials
1. Ryobi Nail Gun
2. Drill
3. Random Orbit Sander
4. Dewalt Table Saw
5. Screws
6. 5/8" Nails
7. Rust-Oleum Spring
a. Rust-Oleum Apple Red
b. Rust-Oleum Black
8. Ryobi HOT GLUE GUN
9. Metal Pipe
10. DEWALT DW618 Router
11. Rockler Circle Cutting Jig
Step 2: Cutting the Two Circles
I got a half sheet of plywood and found the center. Then i tapped a little hole in the center for the jig to guide on.
This wood was 1/2 thick so I took a couple passes to cut it all the way through.
Step 3: Outside of Circle
I got thin plywood for the outside of the wheel. Its about a 1/8" thick. Make sure to cut it in long strips so it will bend easily. The width of the strips I cut were 12"
Step 4: Making the Wheel
I cut down a few pieces of 2x4's to 11" for the inside of the wheel. This would attach the two halfs so I could wrap the plywood around the edge.
I then used a 1 1/4" forstner bit to cut a hole in the middle for the 1" pipe to go through. This is what will make the wheel spin. I then pre drilled a bunch of holes for screws to attach the thin plywood to the circle. I then came back with a nail gun to add more strength to the bond.
Step 5: Finishing and Sanding the Wheel
I used wood filler to cover up the nail holes and as many of the screw holes as I could. Once it was dry I sanded it down and used black spray paint to cover the whole thing.
Step 6: Building the Base
I used 2x4's for this step. The two long pieces that would be on either side of the wheel had a hole cut in it for the pole so that it could spin freely. It was roughly 4 foot tall pieces.
I then cut some 18" inch piece to put between the two halfs. I used pocket holes to attach these. Then I cut some angled pieces to add extra support to the base. I used 2 1/4 inch screws here to keep everything together. I didnt use any glue so I could take this apart.
Step 7: Spinning Issues
Once I had squared up the base the wheel was having a lot of trouble spinning so I used a jig saw to a cut a opening in the side pieces so that the wheel would just drop in and sit on top. This helped a lot with movement and I used some silicone spray to make it spin faster.
Step 8: Section Seperaters
I cut some 1 inch strips of the thin plywood to act as dividers for the wheel. I painted them a metallic silver. I measures out 11.5 inches and attached a strip.
Step 9: The Marker
I needed a way to determine what prize the contestants would win when they spun the wheel. So I used a 25" long piece of wood and a small piece of acrylic. The wood attached to one side of the base and the acrylic triangle was glued on the end.
Step 10: Prize Options
We laminated a bunch of different prize cards and used hot glue to attach them to the wheel. This was so they could be changed in the future.
Step 11: Enjoy Your New Spinning Wheel
Overall I am very happy with this build. It came out great and was a lot of fun. Let me know in the comments below if you have any questions.
