Introduction: Gamer's Sandwich
A true gamer's snack.
A quick and easy pizza sandwich that's perfect for anytime of the day or night!
Inspired by the Playstation controller!!
Step 1: Gather Resources
For a single player:
  • 8 slices of bread
  • Some Capsicum (Bell Peppers) - Half of a large one should be enough. You may go for multiple colors if you like.
  • Some Mushroom
  • A few Olives
  • Mozzarella cheese - or any cheese that you prefer
  • Some sweet corn.
  • Some oil.
  • Salt and any other seasoning of your choice.
  • A pan
  • An oven pre-heated to 150 degrees Centigrade.
Double the quantity if you are two players.
Step 2: Slice N Dice
Dice all the veggies, mushroom and olives as small as you can.
Step 3: Drizzle N Sizzle
  1. Heat some oil in a wide pan at medium heat.
  2. Add the diced mushroom and sweat it a bit.
  3. Add the veggies and saute it for 5 minutes or until the veggies soften slightly.
  4. Toss in the olives and sweet corn and let it cook for a minute or two more.
  5. Reduce the heat to low.
  6. Shred the Mozzarella or any other cheese you like and add it to the mix while it is still hot.
  7. Add salt and any other seasoning to taste.
  8. Keep the mixture warm at low heat and proceed to the next step.
Step 4: Time to Carve
Carve the slices of bread into the shapes shown.
The 4 pieces on the left form the base, the 4 pieces on the right form the top.
  • Triangle - Cut the slice along the diagonal.
  • Square - The whole slice
  • Circle - Use a can / bottle / cookie cutter to get the shape right
  • X - cut four small triangles at the centre of each edge of the slice.
For the top pieces, cut them just like the bottom ones and then hollow them out.
Step 5: Stack Them
  • Put some cheese as shown. This is just to make the top slick to the bottom when the cheese melts.
  • Fill the hollows with the veggie mix.
  • Place the sandwiches on a baking tray.
Step 6: Fire in the Hole
Gently toast the sandwiches in oven for about a minute.
Be careful not to burn the slices
Step 7: Game On
Plate up and Game on!!
