Introduction: Garage Monitor 3001 Paging System
This is an updated paging system for the Garage Monitor 3001( GM3K1).
I was using Nagios before for paging , but after switching to the SheevaPlug I decided to skip installing Nagios and just use a script for this.
Step 1: Pre Reqs
I am going to assume you are running linux and a db. I use Fedora and Mysql.
And obviously you need to run the Garage Monitor 3001.
Step 2: Create Table.
Create a db instance and create a table in it.
CREATE TABLE `status` (
`id` int(11) NOT NULL AUTO_INCREMENT,
`door` enum('overhead','side') DEFAULT NULL,
`status` enum('Open','Closed') DEFAULT NULL,
`date` datetime NOT NULL,
PRIMARY KEY (`id`)
PRIMARY KEY (`id`)
Step 3: Monitoring Script
This is the script I use to monitor the garage, which will grab the page, and insert the status in the database.
#Script to enter garage status in DB
#Joe McManus 2010/01/26
#who mail should go to
$mailto="joe@example.com";
#who mail comes from
$mailfrom="garagemon@example.com";
#set the time
$now=date('Y-m-d H:i');
#web status url
$garageurl="pink.example.com/garagemon-text.html";
#public url to include in page to check status online
$puburl="http://www.example.com/garage.php";
function connect(&$db){
$db = mysql_pconnect("localhost", "garage", "monitor");
if ( mysql_select_db("garagemon", $db)) {
} else {
echo "Sorry we are currently experiences technical issues. We'll be back shortly.";
exit;
connect($db);
#check the page
system("curl $garageurl -o /tmp/garage.txt", $retval);
if ($retval == 1 ) {
echo "Error: Unable to reach web server";
exit;
#Get the door status
$overhead=exec('grep Overhead /tmp/garage.txt | cut -d" " -f2');
$side=exec('grep Side /tmp/garage.txt | cut -d" " -f2');
#insert the side door in to the db
$insert="insert into status(id, date, door, status)";
$insert.="values('', now(), 'side', '$side')";
$result=mysql_query($insert, $db);
#insert the overhead door in to the db
$insert.="values('', now(), 'overhead', '$overhead')";
echo "Overhead: $overhead ";
echo "Side: $side ";
#Query for doors being open 10 minutes or more.
$query='select date, door, status from status where status="Open" and date > date_sub(now(), interval 10 minute)';
$result=mysql_query($query, $db);
$rowcount=mysql_num_rows($result);
$mailfile="/tmp/garagemail.txt";
if ($rowcount >= 2) {
echo "Alert: Door Open ";
//Message start
$mailsubject="Alert: Garage Door Open $now";
$mailmsg="The Garage Monitor 3001 has detected that a door has been open for more than 10 minutes. $now ";
$mailmsg.="$puburl ";
if(file_exists($mailfile)) {
echo "Mail not being sent $mailfile exists ";
} else {
mail($mailto, $mailsubject, $mailmsg);
exec("/bin/touch $mailfile");
} else {
echo "Alert: Garage Door Closed $now";
$mailsubject="Alert: Garage Door Closed";
$mailmsg="The Garage Monitor 3001 has detected that a door has been closed. $now ";
exec("/bin/rm $mailfile");
#Just a query for debugging
$query='select date, door, status from status where date > date_sub(now(), interval 10 minute)';
echo "door | status | date ";
while($row=mysql_fetch_row($result)) {
echo "$row[0] | $row[1] | $row[2] ";
#set the time
#web status url
} else {
exit;
connect($db);
#check the page
exit;
//Message start
} else {
} else {
Step 4: Add to Cron
Add the script to cron, have it run every 5 minutes.
Step 5: Alerts
You will get only get one email if a door is open for 10 minutes or 10 hours, no need to fill up your inbox. You will get one more when it clears.
