Introduction: Garbage Bag Ghosts
These cute little ghosts can be quickly and easily made with just a few household items.
Step 1: Supplies
1 white kitchen garbage bag / bin liner
4-5 white plastic shopping bags
scissors
black permanent marker
chopstick or other long, sharp tool (a large nail will do)
(optional) string or twine
You will be able to make two ghosts from each garbage bag.
scissors
Step 2: Cut Apart the Garbage Bag
1) Cut off the top edge, removing the channel that holds the drawstring.
2) Cut two more strips from the edge of the bag. Cut these strips in half so you have four total.
3) Cut the bag open along the side seams, then cut the bag in half along the bottom fold.
You should have two large squares now.
Step 3: Cut Apart the Shopping Bags
If your shopping bags have printing on one side, cut the bags apart to separate the printing from the blank bag.
Step 4: Make the Ghost's Head
1) Take the printed parts of two or three of the grocery bags and wad them into a ball. Take the other halves of the bags (the blank sides) and wrap them around the ball so that the printing is concealed as much as possible. (Some color will probably show through.)
2) While still holding this wad of shopping bags, drape one half of the garbage bag over the ball, gathering the excess underneath.
3) Use one of the strips cut from the garbage bag to tie the neck of the ghost just below the ball.
Step 5: Tatter the Ghost's Body
Start cutting the bag into strips from the edge towards the neck. Stop your cuts a couple of inches from the neck so they don't get too narrow and fragile. Your cuts will be wider at the bottom and may get quite narrow at the top. (See the second image for a cutting guide.) Perfection isn't needed here. Just try to space them nicely.
If you feel like your strips are getting too narrow at the top while being too wide at the bottom, you can trim the sides of the strips and discard the extra.
Step 6: Add a Face
Pick the spot you like best and use your permanent black marker to draw a face on the ghost's head. Give it a minute before touching the ink or it can smear.
Step 7: Add a Loop for Hanging
1) Take your chopstick (or other long, sharp tool) and poke it into the top of the ghost's head on one side, then back out the other side. (See photos for placement of holes.)
2) Remove the chopstick, then use it to push one of the garbage bag strips through the holes.
3) Holding the ends of the strip, twirl it into a rope, then knot the ends together.
4) Trim the ends of the knot, removing the excess, then carefully slide the loop until the knot is hidden inside the ghost's head.
Now use the rest of the bags to make a second ghost, then go hang your spooky pair somewhere and enjoy!
