Introduction: Garden Bat Box
"Bats signify a healthy green garden" Help out with the preservation of bats with this bat box capable of housing 50 bats, that can be made in just over an hour.
Just before mothers day, I had a little spare time to cobble together a nice little bat box for my mother who had been pestering the whole family to get her one.
There are 18 bat species here in the UK all of them are endangered; they are no bigger than the size of your hand, the largest is about the same size as a Walnut.
So with a little spare time, some scrap wood recycled from an old desk (in my case), you can make yourself a nice professional bat box that looks just like an expensive store bought one.
Important Stuff
Law protects bats and their roosts, it is illegal to kill, injure or take a wild bat, or intentionally or recklessly damage, destroy or obstruct access to a bat roost.
This Instructable uses power tools that can seriously injure, maim and even kill if handled with stupidity.
Updates:
First I'd like to say thanks to those who commented, oh and the feature.
I'll be making a new bat box later next month, probably with a new design as I like to do stuff like that.
Other than that I'll try and upload my instructions for my DIY Telescope/Microscope compact camera holder.
-Grant
Important Stuff
Updates:
-Grant
Step 1: Things You Will Need
Tools and Machinery
Crosscut / Mitre Saw (Crosscut recommended)
Drill Press
Table or band saw
Hammer
Nail Punch
Set square
Plane
Pencil & rubber
Staple gun
Materials
If your shed is anything like my dad's you'll probably find everything there
Note: When I do measurements I usually do it in millimetres in the following format Length 1 x Length 2 x Depth
So 20 x 120 x 2cm would be 20cm by 120cm with a thickness of 2cm.
Untreated Wood: 20 x 120 x 2cm (No excuses! Has to be untreated! )
Nails (thin but long ones)
Clout Nails (Pictured)
Odourless Glue (No excuses! Has to be Odourless! )
Staples (optional)
Netting (optional)
Drill Press
Table or band saw
Hammer
Nail Punch
Set square
Plane
Pencil & rubber
Staple gun
Materials
Staples (optional)
Netting (optional)
Step 2: Cut the Wood Into the Required Pieces
Make sure that the wood is square with the plane or by trimming it with a table mounted circular saw.
Using the table mounted circular saw Cut the wood into these pieces:
20x34cm Sides
20x40cm Roof
15x33cm Back board
23x15cm Door
Keep any scrap wood left over for the doorstops.
Then cut the 20x34cm piece from one corner to the other, so you get two triangles, these will be the sides of the bat box.
20x34cm Sides
20x40cm Roof
15x33cm Back board
23x15cm Door
Step 3: More Cuts
Now comes the tricky part.
Part 1
With your crosscut saw set the tilt of the head to approximately 62% and cut tightly along the length (top part of the image i.e. where 40cm is).
This will make the roof flush with the backboard and will give a nice roof over the bats' heads.
Part 2
This is the important part, adding the hole to the bottom of the box.
The hole has to be inbetween 15mm and 20mm wide to allow the bats in and out but to also keep the temperature regulated correctly inside.
This is where you need to mark the side pieces correctly (Remember it is easier to take away, than to put back )
Mark along to two longest sides the thickness of the wood used for the backboard and door.
Use the two pencil lines and a ruler to find where the gap of 15-20mm is between the pencil lines, mark that up and cut along the dashed line.
Part 1
Part 2
Step 4: Making the Ladder
Bats aren't like birds they can't enter though a hole in the front, nor can they fly up into the bottom like a house martin; they need to land on a ladder (or landing pad) and then climb their way into the bat box.
This is the fun part, But remember safety first before fun (I work for TV and Films so I know what I'm talking about).
But first you need to work out how long you want your ladder, with mine I left a little bit of the back board poking out above the roof that I could use to attach to a surface.
Tilt the head of your crosscut saw back too its upright position, some where on your saw should be a depth gauge, adjust this so that the bottom of the blade reaches about half way of the depth of the backboard.
Too shallow the bats won't have much to grip on, too deep and you risk your box breaking.
Now cut little slits into the wood to make the ladder, just stopping before your roofline.
Step 5: Drilling the Pivot for the Door
The roof sits on top of the side walls, so you want your door to pivot just below this.
To ensure that your door can open, leave a little gap between the roof and door, we'll use some scrap wood to close the opening to preserve heat inside during the winter, it also works quite conveniently as a doorstop as well.
Mark out at the bottom of the side walls where you're going to put the holes for the pivot, make sure that the hole in about the centre of the thickness of the door.
Drill the hole into both parts of the wood, you want the hole to be big enough for the Clout nail to fit through but tight to let little heat escape.
Step 6: Assembly
Now to assemble your bat box, I recommend using nails and a odourless non-toxic glue (the glue has to be odourless and non-toxic ).
Add a smooth stream of glue running down an edge of the Backboard whilst it is in a vice and place the side wall on top and begin to nail it down.
Wipe any excess glue that begins to seep through the gaps.
Tip: use a nail punch to sink the nails flush with the wood.
Do the same with the other side before adding the roof on top; again with glue and nails, but put glue in-between the roof and backboard.
Step 7: Adding the Door
Put the door inside the box, align it up so that its thickness is in the centre of the holes drilled in the side walls.
Get a Clout nail and hammer it in to make a pivot.
Tip: Don't bash the Clout nails in so far that it makes it hard for you to open the door.
Next you want to put in some doorstops, preferably they should fit tightly and run around the inside parameter of the door for weather proofing.
Just use glue as its a bit difficult to nail it in.
Finally with a scrap block of wood, drill a hole through it and use another Clout nail to hammer it near the top, this will be the door knob to stop the door from just falling open.
Step 8: Finishing and Optional Stuff
Well done! You've just made yourself a bat box capable of having 50 bats roosting. But wait there's more!
If you followed this Instructable and made your own, feel free to send pictures and I'll show case them on a separate page.
Stuck, got any questions, liked it? then Comment.
Optional stuff:
Inside I added some netting to allow extra bats to live here. (picture 2)
WARNING! DO NOT paint or varnish your bat box, bats have very sensitive noses, thats why we used odourless glue.
Finding a home for your Bat box:
Now that you've finished your bat box you're probably wondering where you should put it.
Bats use hedges and wall lines to navigate, so it should be placed around there.
The box should at least be 4-5 meters above the ground in a sunny, sheltered but accessible spot.
The Bat Conversation Trust recommends at least 3 boxes for all year roosting placed facing SE, south and SW.
For more information on bats and bat boxes visit:
http://www.bats.org.uk
Optional stuff:
