Introduction: Garden Sign Tinkercad
Today I will show you how to make your own gardening sign with tinkercad. You don’t need to have a lot of experience to make this. You can garden easily with these signs.
Tinkercad (make a free account at tinkercad.com !)
3D printer
3D printer
Step 1: Make the Sign
1.First setup tinkercad on millimeters and select 1.0 on the left bottom of the screen. 2.Than grab a normal cube and make the size 10.00 by 20.00 by 3.00 millimeters. 3. Then grab another square with 3.0 thickness. Make the square 30.00 by 50.00 millimeters. 4. Than grab a triangle from the basic shapes area.5. Rotate it 90 degrees so the point is away from the sign. 6. Make it 10.00 by 20.00 millimeters. After grab the small rectangle and triangle and put the two together than press shift key and click on both of them.7. Make it one shape by clicking the circle and the square that are together. 8. Than bring the bigger square over and do the same thing. Yay done with the hardest part!
Step 2: The Word
You can copy and send paste these signs if you want to have more than one. Final steps!! 1 click text in basic shapes and lift it 1.0 millimeters also make it clear. 2 Click on text and then click the little arrow than type the food you want to make a sign for. 3 Then make it fit your sign complete !!
