Introduction: Gas Sensor With LCD
We are a group of UQD10801 (Robocon1) students from Universiti Tun Hussein Onn Malaysia (UTHM) that will show how to set up a circuit with Gas sensor and LCD.
The reason we chose Tinkercad is because they provide pre-built circuits that can help users to not complicate their circuits by building from scratch.
INTRODUCTION
MQ gas sensors are a family of devices designed to detect the presence of different chemical components in the air. We can connect these devices to an automaton or processor like Arduino. There is a wide variety of MQ sensors. Each model is designed to detect one or more substances, designed for a specific use, such as detection of flammable gases, air quality or detection of alcohol in breathed air. MQ gas sensors are usually provided with a standard measuring plate with the comparator LMC662 or similar, which allows the reading to be obtained both as an analog value and as a digital value when a certain regulated threshold is exceeded through a potentiometer located in the license plate. The gas sensors must be calibrated before obtaining an accurate measurement. Even calibrated these sensors do not have the necessary guarantee to be part of a security system. The sensors output is presented by a LCD screen.
Set up the circuit as the diagram above.
Arduino board
Breadboard small x2
Gas sensor
LCD
Buzzer
Led
Resistor x3
Step 1: Code
CODES
#include
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define buzzerPin 8
#define gasPin A0
void setup() {
Serial.begin(9600);
lcd.begin(16, 2);
pinMode(buzzerPin,OUTPUT);
lcd.setCursor(0, 0);
lcd.print("Calibrating");
for(int i = 0; i <10; i++){
if (i==4)
lcd.setCursor(0, 1);
lcd.print(".");
else lcd.print(".");
delay(500);
lcd.setCursor(5, 1);
lcd.print("done");
delay(1000);
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("SENSOR ACTIVE");
delay(1500);
lcd.clear();
void loop() {
int gasSensor = analogRead(gasPin);
if (gasSensor > 350)
digitalWrite(buzzerPin,HIGH);
lcd.print("Value : ");
lcd.print(gasSensor);
Serial.print(gasSensor);
Serial.print("\t");
Serial.println("Gas is Detected");
lcd.print("Gas is Detected");
delay(300);
lcd.clear();
else if (gasSensor < 350)
digitalWrite(buzzerPin,LOW);
Serial.print("\t");
Serial.println("Gas level is LOW");
lcd.print("Gas leve is LOW");
delay(300);
Step 2: Output
This is how it appears when the gas detected is low.
Step 3: When the Gas Detected Is HIGH
The LED and Buzzer will be turned on.
Step 4: OUR TUTORIAL VIDEO
Watch our video for a full expalnations.
