Gecko - Magnetic Wall Climbing Robot
Intro: Gecko - Magnetic Wall Climbing Robot
GECKO - Natural magnets, super mobility and high simplicity robot.
In this instructable I'll describe my engineering project, made 5 years ago for university graduation.
The project was very promising, and we started to deal with patents and funding for additional development.
- It can climb walls carrying weights
- It can transfer between various geometries
- Its simple ! and perform tricks that much sophisticated robots cant do.
STEP 1: The Patent - Surcface Complient Magnetic Wheel
The basic invention takes the physical properties of the natural magnet - It is very hard to pull it off a surface vertical to the surface that is attached to, but if you try to "peel" , it comes off quite easy. (see figure)
Each magnet is connected to a suspension spring, that acts whenever the robot is moving on a ruff terrain.
our wheel uses this exact characteristic to move efficiently on surfaces - lacking the need for expensive and energy consuming electromagnets or any kind of suction cups.
STEP 2: Lets Start From the End - Please Applaud to the Wall Climbing Robot !
The robot can climb on magnetic surfaces, using its almost patented compliant wheels (OUR invention!!!)
It climbs on vertical surfaces, ceilings, carrying loads and controlled by a remote controller. (regular RC control)
As you can see each magnet is connected to a suspension spring, that acts whenever the robot is moving on a ruff terrain.
STEP 3: Our Gecko Climbs the Stairs
It can also climb stairs !
STEP 4: Our "Followers"...
Since we first launched the project (finished 2008) , many "original" similar projects popped, and we proudly declare that we were the first! they just took our idea...
Feel free to contact, and If you by any chance an investor - You're welcomed ! There's a huge market waiting for this solution.
g.nite.
g.nite.
7 Comments
rohan14 10 years ago
Hi, can we attach a suction cup by replacing the magnet to adhere to a glass surface. I am asking because I am in a process to develop a window cleaning robot but looking for some suction technology to stick to the glass surface. waiting for your reply.
garrettg7 8 years ago
hey man, I know it's been 2 years but if your still working on the bot try using Geckskin: https://geckskin.umass.edu/
wavegm 10 years ago
Suction cup can be placed instead. while calculating the required forces and design factor. the basic "peeling" solution works similar.
Will be glad to see your project. Good luck.
Navdeept 8 years ago
which magnets have you used in this?
Kiteman 11 years ago
Can it climb real walls, where the steel is behind a layer of glass, brickwork or drywall?
wavegm 11 years ago
If you want to dive real deep you can "in future model" replace the magnets in artificial adhesion hair (as in Gecko's feet).
this hair is currently under development in some advanced research labs.
Penolopy Bulnick 11 years ago
