Introduction: Gel Dispenser - USMP
Hi guys!
I'm Juan Diego Rodriguez Obregón. I study Architecture at the USMP (San Martín de Porres University)
Today I am going to teach you step by step how to create a Gel Dispenser, for all those people who want to have an entertaining and educational time.
I hope you like!
Step 1: Materials
- Computer:
- Procesador Intel Core i5-10400F.
- Velocidad procesador máx. 4.30GHz
- RAM de 8 GB.
- Gráfica: Nvidia GTX1650-4GB.
- Disco 256GB SSD más 1TB HDD.
- Peripheral mouse.
- Internet connection.
- Eager to learn.
Step 2: Elaboration of the Base
Step 1: To start with the base we are going to click on the icon called ¨Create Sketch¨, after creating our Sketch we are going to select the "X" and "Y" axes.
Step 2: With the tool called "Line" we will begin to draw lines according to the measurements that are in the photo. When we finish drawing and closing the figure, a light blue base will be formed within the lines drawn.
Step 3: After closing the figure with lines we are going to give the box called "Finish Sketch", then we are going to give the box called "Extrude", we select the figure we made and specify the distance to extrude that would be 3.00 mm.
Step 4: To finish this step, we are going to select our figure and I will give the option called "Appearance", we choose the color and texture we want. Don't forget to save your work.
Step 3: Elaboration of Side A
Step 1: We created a new design and called it Face A. We are going to click on the icon called ¨Create Sketch¨, after creating our Sketch we are going to select the "Y" and "Z" axes.
Step 3: In Face A we have 2 rectangles in the lower part, to make these rectangles we are going to select the box called "2 - Point Rectangle" and create two rectangles in the lower part with the measurements that are in the image of this step.
Step 4: We are going to give the box called "Finish Sketch", then we are going to give the box called "Extrude", we select the figure we made and specify the distance to extrude that would be 3.00 mm. and we are going to select our figure and I will give the option called "Appearance", we choose the color and texture we want.
Step 5: Now we are going to save our design in our folder in which we are saving all our designs.
Step 4: Elaboration of Side B
Step 1: We created a new design and called it Face B. We are going to click on the icon called ¨Create Sketch¨, after creating our Sketch we are going to select the "Z" and "X" axes.
Step 3: In Face B we have 1 rectangle in the lower part, to make this rectangle we are going to select the box called "Rectangle of 2 Points" and we will create a rectangle in the lower part with the measurements that are in the image of this step.
Step 4: In Face B we also have 2 circumferences in the upper part, to make these circumferences we are going to select the box called "Center Diameter Circle" and we will create a circumference in the upper part with the measurement of 3.00 mm.
Step 5: We are going to give the box called "Finish Sketch", then we are going to give the box called "Extrude", we select the figure we made and specify the distance to extrude that would be 3.00 mm. and we are going to select our figure and I will give the option called "Appearance", we choose the color and texture we want.
Step 6: Save, assemble and print the Gel Dispenser.
