Introduction: Geometric Dome Slide Platform
Hi, Everyone!
For the last two years, I have had a green slide tucked away under my back porch. Recently, my wife had the idea to attach the slide to the top of our geometric dome. I started this build with only an idea in my head, and I developed the final design as I went. However, I am very pleased with the result. I used a few 2x4s, 2x6s, and three-inch screws from my shed to create the basic platform to which I attached the slide and Bingo Bango...hours of backyard fun and physical fitness for my kids!
Unfortunately, I did not take pictures of the build process. But, hopefully, this brief Instructable will inspire and help you to build a similar setup. I also included a basic Sketchup model for your visualization and planning. Overall, this project cost less than $30 (minus the slide) and was an easy Saturday morning build.
It's a pleasure to share this idea with you, and I hope you create something even more fun from it! I wish you and yours the very best!
Thanks sincerely,
David
- 2"x4"x8' Wood Boards; Qty. 2
- 2"x6"x8' Wood Board; Qty. 1
- Box of 50 Three-Inch (3") Outdoor Construction Screws; Qty. 1
- 3/8"x3"x6" U-bolts (design-dependent); Qty. 2
- 3"x6" steel plates - 1/16" thick; Qty. 2 (typically found in roofing or lumber section of Home Depot)
- 1/4"x4" steel bolts with nuts (to attach slide); Qty. 3
- 1/4" steel washers; Qty. 6
Tools
- Hand drill with a Phillips or star bit (construction screw dependent)
- 3/8" and 1/2" drill bits (for U-bolts and slide)
- Adjustable wrench; Qty. 2
Step 1: Build a Basic Platform
The basic platform dimensions will differ, pending the size of your geometric dome. However, the basic platform I built is 24" x 16" on top (see the Sketchup model for complete dimensions).
Step 2: Add a Brace That Spans Two Dome Trusses
The horizontal brace distributes the platform load across a greater area, ensuring safety and stability.
Step 3: Use a Level to Position the Platform
Leveling the platform is very important so that your kids can safely transition from the dome to the surface of the platform.
Step 4: Add Feet to Maintain Position Behind the Main Supporting Truss
The feet ensure that the platform does not move forward off the main supporting truss.
Step 5: Add a Horizontal Brace Behind the Main Supporting Truss
The horizontal brace allows for U-bolts to secure the platform to the dome and increases overall structural strength.
Step 6: Secure the Horizontal Brace to the Main Supporting Truss Via U-bolts
The U-bolts ensure that the platform stays firmly attached to the dome at all times.
Step 7: Attach Your Slide
Make sure you pick a slide that is the correct height for your dome.
