Introduction: Geometry Honors Final Exam Practice
This is a practice Geometry Honors Final Exam with clues and answers. I hope it's useful!
Step 1: Which Is the Distance Between Points (-3, 4) and (2, 5)?
- 5
- 24
- √24
- √26
- 26
d=√((x_2-x_1)²+(y_2-y_1)²)
Answer: 4) √26
Step 2: Conditions
Let p represent "I live in Virginia" and q represent "I am an senior". Which is the symbolic notation for "I live in Virginal and I am not a senior"
- p∧∼q
- p∨∼q
- p→∼q
- p⟷∼q
and = ∧
Answer: 1) p∧∼q
Step 3: Triangle Angle Proofs
What additional piece of information would prove △LMK≅△NMK by side-angle-side?
- ∠MLK≅∠MNK
- MK (line segment) bisects ∠LKN
- ∠LMK≅∠NMK
- M is the midpoint of LN (line segment)
Line segments LK and NK are equal and both triangles share the same line segment MK.
In one step, only angles ∠MKL and ∠MKN have to be congruent.
Bisecting means splitting something in to equal halves.
Therefore, line segment MK should bisect ∠LKN in order for both triangles to be congruent by side-angle-side.
Answer: 2) MK (line segment) bisects ∠LKN
Step 4: Which Is Closest to the Area of the Shaded Sector of Circle C?
- 38 cm^2
- 45 cm^2
- 34 cm^2
- 29 cm^2
Answer: 4) 29cm^2
Step 5: Similar Triangles
Based on the given information, which diagram contains a pair of similar triangles?
Answer: Image 3
The sum to all angles of any triangle is 180 degrees
64+25+X=180
X=91
Therefore, the triangles are similar.
Step 6: Area of a Hexagon
What is the area of a regular hexagon with apothem length of 9?
- 162√3
- 486√3
- 162√2
- 4862√
A=(3√3)/2 a^2
a= side
Answer: 1) 162√3
Step 7: Volume of a Sphere
Mikayla is filling a glass sphere with water. If the diameter of the sphere is 12 inches, what is the minimum amount of water she needs to completely fill the sphere?
- 288π in^3
- 2,304π in^3
- 144π in^3
- 576π in^3
V = 4/3 π r³
diameter = 2r
Answer: 1) 288π in^3
Step 8: What Is the Midpoint of the Segment With Endpoints (-6, 3) and (3, 6)?
- (-4.5, -1.5)
- (-1.5, 4.5)
- (0, -2)
- (12, 9)
midpoint formula: ((x1 + x2)/2, (y1 + y2)/2)
Answer: 2) (-1.5, 4.5)
Step 9: Hexagons
If each interior angle of a regular hexagon measures (13x+3)°, which is the value of x?
- 11
- 9
- 10
- 12
Answer: 9
Step 10: True or False
Three points are always coplanar. = True
If two angles are supplementary, then they form a linear pair. = False
If the sides of a triangle are 2√6, 3√2, √6, then it is a 30-60-90 triangle. = True
The converse of p → q is q → p = True
AA is a way to prove two triangles are congruent. = False
The interior angles of a pentagon sum to 900 degrees. = False
The center of circle (x−9)^2 +(y+2)^2=81 is (-9, 2). = False
The diagonals of a rhombus are always congruent. = False
The sum of the lengths of two sides of a triangle is always greater than the length of the third side. = True
Opposite rays form a line. = True
Step 11: What Value of X Would Prove A∥b?
- 8
- 11
- 10
- 9
Answer: 1) 8
Step 12: Equilateral Triangle
If △ABC is an equilateral triangle and BD = 36 inches, find the value of x.
- 18√3
- 12√3
- 24√3
- 36√3
Answer: 3) 24√3
Step 13: Finding Angles
- 66°
- 52°
- 34°
- 38°
Answer: 4) 38
Step 14: Always, Sometimes, Never
If AM = MB, then M is the midpoint of AB = Sometimes
Alternate interior angles are congruent. = Sometimes
An equilateral triangle is isosceles. = Always
The diagonals of a rhombus are perpendicular. = Always
Two right triangles with congruent hypotenuses are congruent triangles. = Sometimes
The contrapositive of a true conditional statement is false. = Never
An isosceles triangle has a right angle. = Sometimes
Vertical angles are congruent. = Always
The lateral area of a solid includes the area of the solid's bases. = Never
Three points determine a plane. = Sometimes
Step 15: Distance
An 85 foot wire is tied from the top of a utility pole to the top of a building as shown. Find d, the distance from the pole to the building. Make sure you are in degree mode!
- 75.2 ft
- 78.8 ft
- 80.5 ft
- 82.1 ft
Answer: 2) 78.8 ft
Step 16: Given Circle S, Find M∠TUV ?
- 28 degrees
- 32 degrees
- 58 degrees
- 36 degrees
Answer: 2) 32 degrees
Step 17: Triangle Angles
Park Street, Scott Street, and Oak Street form a triangle. If the angle formed by Oak Street and Park Street is 62°
62° and the angle formed by Park Street and Scott Street is 58°
58°, list the sides of the triangle from least to greatest.
Answer: 1) Oak Street
2) Park Street
3) Scott Street
Step 18: Which Line Represents a Line Parallel to Y=-2x + 9?
- 4x-2y=10
- 2x-4y=28
- 2x+4y=28
- 4x+2y=10
Parallel lines have the same slope.
Answer: 4) 4x+2y=10
Step 19: Surface Area
The volume of Prism A is 1,536 m^3 and the volume of Prism B is 375 m^3. What is the ratio of their surface area?
- 512:125
- 64:25
- 8:5
- 16:25
Answer: 2) 64:25
Step 20: Which Angle Measure Is Closest to the Value of X?
Make Sure You Are In Degree Mode!
- 39.8 degrees
- 50.1 degrees
- 56.4 degrees
- 33.6 degrees
Answer: 4) 33.6 degrees
Step 21: Right Triangles
Given the side measures, which of the following could form a right triangle?
- 55 ft, 45 ft, 35 ft
- 24 in, 34 in, 28 in
- 61 m, 60 m, 11 m
- 48 cm, 46 cm, 15 cm
Answer: 3) 61 m, 60 m, 11 m
Step 22: If QRST Is an Isosceles Trapezoid, Find the M∠R.
- 118 degrees
- 125 degrees
- 107 degrees
- 113 degrees
Answer: 4) 113 degrees
