Introduction: Get Creative With the Instructables
These are the materials that you need:
1. 5V DC motor
2. LED light
3. Cardboard (you need a lot)
4. Hot glue
5. White glue (it can be school glue too)
6. Scissors or cutter
7. Connecting wires
8. Parchment paper (optional)
Step 1: We Make Circular Rings * 4(Cardboard ) and Be Perforated in the Center.
Step 2: And Then Glue the Loops.
Step 3: Then We Bring a Piece of Cardboard (2.5*8 Cm) and Cut the Beginning of the Piece in the Shape of a Crescent.
Step 4: And We Cut the Ends "as Shown in the Picture" , and Bows the Cardboard .
Step 5: Glue the Carbon Piece on the Rings Assembly.
Step 6: We Wrap a Piece of Cardboard (30*12 Cm) on a Silicone Tube.
Step 7: The End of the Cardboard Piece and the Silicone Tube Is Affixed, We Install the Mortar on a Small Piece of Cardboard .
Step 8: Then We Paste the Rest of the Pieces "as in the Picture", and Put a Little Adhesive on the Motor Pipe.
Step 9: Then We Paste Fan With Motor .
Step 10: Then We Paste Column (in Step 6) With Motor Base .
Step 11: Then We Paste Column (in Step 6) With a Square and Small Piece of Cardboard .
Step 12: Square Piece of Cardboard (12*8 Cm >> Step 13 ) for Home, Tape a Small Piece of Parchment Paper and Also Tape Two Pieces of Cardboard to Make the Window.
Step 13: We Need Two More Pieces of Cardboard(8*6 Cm).
Step 14: Glue the Cardboard Together .
Step 15: We Glue the Wire and the LED Light.
Step 16: Glue the Cardboard Together .
Step 17: Glue the House to the Base of Cardboard .
Step 18: Then We Connect the Cable Between the LED Light and the Motor.
Step 19: Final
Note:
motor or ligh It is not connected with bettery because it is based on principle of turbine generator. Let me explain, in motor we have some copper windings and two magnets. If we can rotate those copper windings between those two magnets it produces some electricity ( based on the principle of Faraday's law of electromagnetic induction), this electricity is transfer to L.E.D bulb that is the reason why the bulb blinks without any battery. Here I use a permanent magnet DC motor so it can be used as a DC generator. Configuration of DC motor is 12 volt 3400 r.p.m and 3 volt L.E.D. To make the fan ( which is fixed with the motor shaft ) rotate we have to blow it with some external wind source. For this I use a table fan but it is not shown in the photos....Thank you.
