Introduction: Get Perfect Tie Length Every Time
How many times do you have to tie your tie before you like it? It's too short, or too long! Now you won't have that problem.
Tie
Step 1: Measuring
Tie your tie the way you like it.
Get a marker of some kind and make a mark on the back of the long side above the knot. (White dot)
Make another mark on the back of the tie where it comes out the bottom of the knot. (White dot)
What you have done is marked the length of the tie it takes to make the knot.
Step 2: Transfer Measurement
Take your tie off and measure the distance between the marks.
Step 3:
Take this measurement and make another mark up from the bottom tip of the tie.
When you tie your tie the next time, place this mark where you like the tip of your tie to be.
Some men like it to be at the top of their belt buckle.
If your ties are all the same length, mark them all now. If you have ties of different widths or thicknesses of material, you might have to do this on all the different ones.
Now you can have perfect length every time without having to tie your tie over and over again.
