Introduction: Getting Started With ESP32 on a Mac
About ESP32
ESP32 is a low cost and low power system on a chip microcontroller with integrated Wi-Fi & dual-mode Bluetooth. ESP32 is created and developed by Espressif Systems, a Shanghai-based Chinese company, and is manufactured by TSMC using their 40nm process.
Task
ESP32 Development Board will be used to blink an embedded LED infinitely.
- ESP32 Module
- Arduino IDE
- Programming cable (micro USB cable)
- Breadboard (optional)
Step 1: How to Connect Your ESP32 to a MacBook
- Install the driver in order to communicate UART through USB.
- Go to Preferences/Security & Privacy and allow the driver to run, and restart the Mac.
- Connect your Micro USB to your ESP32 Board.
- Run $ ls /dev/cu.* and you should now see /dev/cu.SLAB_USBtoUART.
Before starting the next step, make sure you have the latest version of the Arduino IDE installed in your computer. It can be found by the following link.
Step 2: Installing ESP32 Add-on in Arduino IDE
- In your Arduino IDE, go to File> Preferences
- Enter https://dl.espressif.com/dl/package_esp32_index.j... into the “Additional Board Manager URLs” field. Then, click the “OK” button.
- Go to Tools > Board > Boards Manage.
- Search for ESP32 and press install button for the “ESP32 by Espressif Systems“.
- Close a window
Step 3: Writing Code for Arduino
Plug the ESP32 board to your computer. Open Arduino IDE, follow these steps:
- Select your Board in Tools > Board menu (in my case it’s the ESP32 DevModule)
- Select the Port /dev/cu.SLAB_USBtoUART.
- Write down the following code
* ESP32 LED Blink Example */ #define LED 2 void setup() { // Set pin mode pinMode(LED,OUTPUT); } void loop() { delay(500); // 500ms digitalWrite(LED,HIGH); // Turn on LED delay(500); // 500ms digitalWrite(LED,LOW); // Turn off LED }
Step 4: Blinking a Built-in LED on ESP32
Press the Upload button in the Arduino IDE. Wait a few seconds while the code compiles and uploads to your board. After uploading program you will find on board BLUE LED will start Blinking.
