Introduction: Getting Started With the ESP8266 ESP-01
The ESP8266 ESP-01 is a Wi-Fi module that allows microcontrollers access to a Wi-Fi network. This module is a self-contained SOC (System On a Chip) that doesn’t necessarily need a microcontroller to manipulate inputs and outputs as you would normally do with an Arduino, for example, because the ESP-01 acts as a small computer. Depending on the version of the ESP8266, it is possible to have up to 9 GPIOs (General Purpose Input Output). Thus, we can give a microcontroller internet access like the Wi-Fi shield does to the Arduino, or we can simply program the ESP8266 to not only have access to a Wi-Fi network, but to act as a microcontroller as well. This makes the ESP8266 very versatile, and it can save you some money and space in your projects.
In this tutorial we are going to show you how to set up the ESP-01 Wi-Fi module, configure it, and verify that there is communication established between the module and another device.
Step 1: Materials
These are the components that you will need:
Step 2: ESP-01 Setup
When you buy the ESP8266 ESP-01, it comes with a pre-installed AT firmware. It is possible to program the chip with another firmware such as NodeMCU, for example. However, AT firmware is compatible with the Arduino IDE, so we are going to use this firmware for this tutorial. If you want to know how to install a different firmware, then read the Miscellaneous section in this tutorial.
First use the jumper wires to connect the Wi-Fi module to the Arduino as shown in these images.
Step 3: ESP-01 Setup Continued
Upload the BareMinimum example to ensure that no previous programs are running and using the serial communication channel. Next, open the serial monitor and type the following command:
AT
You should get an “OK” response. This means that the module is working and that you are good to go. Now we are ready to test a two way communication between the module and another device.
Step 4: Basic AT Commands
The ESP8266 ESP-01 module has three operation modes:
- Access Point (AP)
- Station (STA)
- Both
In AP the Wi-Fi module acts as a Wi-Fi network, or access point (hence the name), allowing other devices to connect to it. This does not mean that you will be able to check your Facebook from your device while the ESP-01 module is operating in the AP mode. It simply establishes a two way communication between the ESP8266 and the device that is connected to it via Wi-Fi.
In STA mode, the ESP-01 can connect to an AP such as the Wi-Fi network from your house. This allows any device connected to that network to communicate with the module.
The third mode of operation permits the module to act as both an AP and a STA.
Step 5: Basic AT Commands - STA Mode
In this tutorial, we are going to set the module to operate in STA mode by typing the following command:
AT+CWMODE=1
The corresponding number for each mode of operation is as follows:
- STA = 1
- AP = 2
- Both = 3
Step 6: Basic AT Commands - Check Mode
If you want to check what mode your Wi-Fi module is in, you can simply type the following command:
AT+CWMODE?
This will display a number (1, 2, or 3) associated with the corresponding mode of operation.
Step 7: Basic AT Commands - Connecting Wi-Fi Network
Once we have the ESP-01 operating in STA mode, we need to connect to a Wi-Fi network. First we can check if we are already connected to one by sending the command:
AT+CIFSR
This will display the station IP address of our ESP-01 module. If you don’t get an IP address after entering the previous command, use the following command to connect to your network:
AT+CWJAP= “Wi-FiNetwork”,“Password”
Type the name of your Wi-Fi network and the password to connect to it. Make sure you include the quotation marks. After a couple of seconds, you should get an "OK" response. You can check again to see if you have an IP address using the AT+CIFSR command.
Step 8: Basic AT Commands - Enable Connections
Then we need to enable multiple connections before we can configure the ESP8266 ESP-01 module as a server. Type the next command:
AT+CIPMUX=1
Once again, each number is associated with a type of connection:
- Single = 0
- Multiple = 1
The following step is to start the server at port 80:
AT+CIPSERVER=1,80
The first number is used to indicate whether we want to close server mode (0), or open server mode (1). The second number indicates the port that the client uses to connect to a server. We chose port 80 because this is the default port for HTTP protocol.
Step 9: Basic at Commands - Response
Now, when we open a web browser and type the IP address of our ESP module we get the following response as shown in the image above.
This is the HTTP request that our computer sends to the server to fetch a file. It contains some interesting information such as what file you want to retrieve, name of the browser and version, what operating system you are using, what language you prefer to receive the file in, and more.
Step 10: Basic AT Commands - Send and Display Data
We can now use the following commands to send some data and display it in our web browser’s window:
AT+CIPSEND=0,5
The “0” indicates the channel through which the data is going to be transferred; while “5” represents the number of characters that are going to be sent.
When we hit enter, the symbol “>” appears. This indicates that we can now type the characters that we want to send to the browser. In this example we chose “hello.”
After a couple of seconds we get the response "SEND OK." This means that the data has been transmitted successfully to the client. However, nothing appears on the web browser’s window yet. This is because it is required to close the channel first in order to display the characters. We use the following command to close the channel:
AT+CIPCLOSE=0
“0” indicates the channel that is being closed.
Once we hit enter, our message is displayed on the web browser’s window as shown in the image above.
You can refer to the following site to see the ESP8266 AT Command Set:
http://www.pridopia.co.uk/pi-doc/ESP8266ATCommands...
Step 11: Check That Our ESP-01 Receives Data - Mobile Telnet
Now we want to check that our ESP-01 module receives data. We will use the Android application “Mobile Telnet” to test this.
- Open the Android application and from the menu select “Telnet Settings."
Step 12: Check That Our ESP-01 Receives Data - Mobile Telnet Con.t'
Type in the IP address and the port number.
Click “OK” and from the menu select “Connect.”
Step 13: Check That Our ESP-01 Receives Data - Mobile Telnet Con.t'
Type the characters that you want to send and then click the “Send” button.
Step 14: Check That Our ESP-01 Receives Data - Mobile Telnet Con.t'
We get the following response as shown in the image above on the serial monitor.
The message is successfully received and displayed.
Step 15: Check That Our ESP-01 Receives Data - PuTTY
Instead of Mobile Telnet, you can also use PuTTY to check that the ESP-01 is receiving data correctly. You can download PuTTY here.
If you decide to use PuTTY follow these steps:
- Open the program
- Select “Telnet” as the connection type
- Type the IP address and the port number
- Click on “Open"
Step 16: Check That Our ESP-01 Receives Data - PuTTY Con.t'
5. Type the characters that you want to send and hit “Enter.”
Step 17: Check That Our ESP-01 Receives Data - PuTTY Con.t'
We get the same response as before.
Step 18: Miscellaneous - Different Firmware
If you want to use a different firmware such as NodeMCU, you need to download an ESP8266 flasher such as this one. Then you need to download the binary file. You can use the following site to do it. Make sure you download just the integer type.
Step 19: Different Firmware Set-up Con.t'
Open the ESP8266 flasher and select the bin that you just downloaded. Select the serial port and type 0x40000080. Before you click on “Download,” make sure you ground GPIO0. This is required every time a new firmware is being flashed.
When you click on “Download” the flasher will delete the current firmware and start installing the new one.
Step 20: Different Firmware Set-up Con.t'
Once the firmware has been installed, you can disconnect GPIO0 and use it normal.
We hope you enjoyed this Instructable, and you can find more tutorials about the ESP8266 and more on Jaycon System's website.
If you have any questions about this tutorial, do not hesitate to post a comment, shoot us an email, or post it in our forum.
Thanks for reading!
11 People Made This Project!
- miniil made it!
- cblsaindon made it!
- Shegs_ made it!
- weckker made it!
- ElectroFreak217 made it!
- chezjako made it!
- Manu83 made it!
- FlorentinM made it!
- hlousv1 made it!
See 2 More
171 Comments
3 months ago
Tks for the tutorial, it´s very detailed. I already have configured my ESP01 and it was working, but today as I turn the computer and the arduino on, I´m getting the error "connection actively refused". Any tips ???
Tip 1 year ago
Guys if you get an ERROR after typing your wifi name and password and you've done everything like the tutorial just use AT+RESTORE, then proceed again from the beginning.
Reply 4 months ago
I suppose you mean . . . . AT+RST
4 months ago
I seem to be stuck on step 10. When I close the channel I do not get the response back from the web browser
2 years ago on Step 2
Are you sure the ESP can be connected to the Arduino without a 5V-3,3V convertor between arduino's Tx and the ESP's RX? A mistake here could damage the ESP.
I have the feeling this instructable is incomplete... (and potentially hazardous for the elektronics)
Reply 8 months ago
Conveniently, the ESP8266 will accept 5 V for logic but only 3.3 V for power.
Tip 2 years ago
Communications tip: Things to check when it's not responding to "AT" as you expect.
1. Check you baud rate. The ESP units I got from Amazon default to 115200 baud (I tend to use 9600, so needed to change)
2. Line ending (options on bottom right of serial console). Ensure you set this to "Both NL & CR" (commonly called CR/LF). Other options will cause errors (or no response)
3. Watch out for tailing spaces. When pasting AT command, copied from this indestructable, you may inadvertently include trailing space(s) at teh end of the command - that will cause an "ERROR" response. Make sure you delete and trailing spaces before sending the command.
Reply 9 months ago
Thank you!
Reply 2 years ago
You sir are an absolute hero. Tip 2 saved my day.
Reply 2 years ago
Wow thanks great recap simple and to the point
1 year ago
Hello and thanks for this project.
Everything goes well until I check for an IP and the return I get is "192.168.0.100" which is correct apart from the third element which comes back a zero instead of a one.
My internal network has the following IP - xxx..1.xxx, so I cannot get any further with connection etc. I've tried to upload my usual IP number to the ESP8266 but it gives me an error. I don't understand why on a legitimate request, the ESP8266 comes back with one group/digit incorrect within the IP?
Any help would be gratefully accepted.
Ted.
1 year ago
Hi.
I am a hobbyist and great fan of you. After fully and thoroughly going through your post. I have also create a post of ESP 01 for my blog but instead of arduino I use FTDI USB to TTL Serial Adapter Module. Kindly, comment on it.
https://automationcraze.com/esp01-pinout/
1 year ago
AT+CIFSR returns:
+CIFSR:STAIP,"0.0.0.0"
AT+CWJAP="MyNetwork","MyPassword" returns:
+CWJAP:1
FAIL
Shouldn't an IP be returned from my network with CIFSR?
And I assume that is why login failed with CWJAP cmd.
Appreciate the help.
Reply 1 year ago
Did you put your wifi details in or just type that?
Reply 1 year ago
I used the actual SSID and password in my code. I have tried 6 of these WiFi units and they all respond exactly the same way. I know the WiFi works because I'm online at this moment via the WiFi I am trying to connect to.
1 year ago
When I try to find the ip adress it comes up with 'error'. I try connecting again and it still comes up with error. How do I fix this?
AT+CWJAP="MySSID","MyPassword"
WIFI DISCONNECT
WIFI CONNECTED
WIFI GOT IP
OK
AT+CIFSR
ERROR
Reply 1 year ago
Never mind, it turns out I was putting a space after the command :)
2 years ago
I get the following error when I upload the code to the Arduino board.I have made all the connections as you have told,I am not able to cross the first step the esp 01 module is on but nothing happens,please go through the image and help me asap
Reply 1 year ago
When that happened to me it was when I blew up my Arduino's serial converter and needed to replace the board. :/
Reply 2 years ago
Make sure no pins are connected to TX and rx of arduino uno while uploading the bare minimum code
