Introduction: Getting Started With the HAAS Mill
Step 1: Allowed Materials for the HAAS Mill
Allowed Materials
- Metal
- Plastic
Banned Materials
- Metal
- Carbon fiber and composites
If at Pier 9, see Shop Staff first before using these materials:
- All other materials
If you are working from another studio or workshop, refer to the tool's instruction manual to see if your desired material is suitable for tool use.
Step 2: Safety
Our most important safety callouts are highlighted in yellow throughout this course.
Step 3: Machine Specifications
The Haas VF2SS CNC mill is a large, powerful mill with the following specifications:
- 30 horsepower spindle
- 12,000 RPM maximum spindle speed
- Traverse (rapid relocation) speed up to 1,400 inches per minute
- On Pier 9 you are required to operate the mill at 5% rapid.
- All non-cutting moves and tool changes will happen at 5% of the maximum speed so that you have time to react if something goes wrong.
- A reduced rapid speed will not change the cutting speed.
- Work envelope of 30” x 16” x 24” (X, Y & Z)
- Tool carousel can hold up to 24 tools
Step 4: Required for Use
Before you start your work, make sure you have the following materials:
- An .nc file from your completed CAM file
- A thumb drive to copy the .nc file to the mill
- Setup Sheets from your CAM software
- A copy of this Quick Start Guide
Step 5: Steps for Successful Use
To make a part, you need to complete each step in order.
- Start up the mill.
- Insert custom tools into the holders.
- Inspect the Pocket Tool Table and Carousel.
- Install tools into the machine.
- Set the tool offsets.
- Set the Work Coordinate System.
- Load the program.
- Run the program.
- Clean up.
