Introduction: Getting Stoned
About: Im a chef, im a parent , also im an artist and was the studio assistant for the collage for several years I built haunted houses for 10 years did stage crafting for 6 owned my own carpentry business for 4 ye…
Now that I have gotten your attention and, Aggravated, Enthused Aroused or Enraged you. I got you to take a look and it is not what you think . For this Instructable we will be making Concrete Roses. I used To make these all the time for Art insulations and sculptures they are quite easy a little fragile but long lasting and beautiful. This is the first time I have made them with the attention of using the stem in the finished piece and I decided that the wire is too flimsy and will need to be replaced with a thicker gage wire to last the test of time.
Step 1: GET YOUR BOWL
  • METERIALS
  1. Portland Cement
  2. Plaster of Paris
  3. Bowl
  4. Water
  5. Dollar store roses
  6. Plastic Cups
  7. Paint
  8. Something to hang stuff on
  9. Straws
  10. POT
Step 2: Remove the Roses
Pull the roses by the stem to the bottom of the cluster until the wire comes out of the plastic .Then bend the exposed metal into a hook.
Step 3: Mix
  • The mix I use is two parts water to equal parts (1 part each) Cement and plaster. Add water then mix in the cement and plaster mix till smooth .It is in your best interest to use some sort of dust protection like a mask or bandana . If desired add some paint to the mix, this helps to color the deep pockets in the roses.
Step 4: Dip the Roses
Dip the roses in the cement mix , give it a shake and dip again . Hang on your something and let dry . I tried to dip a live daylily and it didn't work out to well it kinda melts and shrugs off the cement as it dries . But I do believe that dried flower will work , No rotting and should suck up the cement
Step 5: While Waiting for Roses to Dry Get Your POT
Take the remaining cement and mix in some dark color like black or brown and load up the pot with cement then insert straws into the pot ,These will hold the roses in place
Step 6: Give Them a Coat of Paint and Insert Into Staws
paint the flowers and insert the roses into the straws into the pot or you can do what I did and removed the pot and made it look like a clump of dirt .Your roses will last forever and if you like to smell the roses you can pour on some rose oil and it will suck into the cement and smell for a long time . Hope you enjoyed go out and make something .
