Introduction: Getting More I/O Pins on ATTiny With Shift Registers
If you previously worked(or currently working) with small 8-bit microcontrollers, like ATTiny or PIC12, you've probably encountered a fundamental problem of not having enough GPIO pins for your needs or project requirements.
Upgrading to a larger MCU is only one of the options, but as usual there is an alternative. In this article I will explain how to use shift registers in some common situations in order to expand the I/O capacity of your microcontroller. As an example I will use an ATTiny13A and a 74HC595 shift register.
Step 1: First Date
Shift register is a semiconductor device which accepts serial input and produces parallel or serial output depending on how you use it. Also, as almost all semiconductor ICs, shift registers have gotten very cheap, so instead of spending relatively small sum of +$1.00 on a single different microcontroller you should get a handful of those 74HC595's at $0.12 apiece.
74HC595 is an 8-bit serial-in, serial or parallel-out shift register with output latch and 3-state output. In order to understand what it is let's look at the functional diagram of this device:
We feed serial input bit-by-bit through DS pin, while providing clock signal to SHCP pin in order for shift register to shift its contents. If we want to save the 8-bit input data, we have to toggle STCP pin to latch the contents onto the storage register. This gives us the ability to "hold" the old output while feeding 8 bits of the next output. Pin Q7S is used for cascading, which means if we have 2 shift registers and we connect Q7S output of the first one to the DS pin of the second one, we get a 16-bit shift register! And, as you should've noticed, we only need 3 pins to use its essential functions (DS, SHCP and STCP).
A pinout diagram for our shift register is shown above.
Most of the pins were described earlier, but there are 2 more left:
- OE (Output Enable): is active low. When set to 1 it disables the output and sets pins Q0...Q7 to a high-impedance state.
- MR(Master Reset): is also active low. When set to 1 it clears the contents of the shift register (not the latch).
We are not using either of these pins for this project, so OE must be connected to ground, while MR is connected to VCC, which will keep output pins in the on-state all the time and will prevent shift register from resetting. In order to clear the contents of the shift register we are just going to send it the value 0x00 just like regular data. To learn more about this device please read the 74HC595 datasheet.
Step 2: Example #1 [OUTPUT]
Code
We are going to read an 8-bit value from ADC3 (most significant bits) and then pass the corresponding output value to our shift register.
To be more specific I've made a table of values for I/O states:
| ADC3 value | Output value | Segments on |
| 0..40 | 0xFF | 0 |
| 41..80 | 0xFE | 1 |
| 81..120 | 0xFC | 2 |
| 121..160 | 0xF8 | 3 |
| 161..200 | 0xF0 | 4 |
| 201..255 | 0xE0 | 5 |
NOTE: Because it is a common anode LED indicator we need to set the appropriate pin LOW whenever we want it to light up.
Now, let's write some code.
In short, we need to set up a Timer Overflow interrupt, which will read the current state of ADC3 and send the corresponding value to our shift register approximately every ~27ms.
SEND_BYTE subroutine sends an 8-bit stream of data and latches it in the shift register. This is a bit simplified function, but with some minor improvements can be used universally.
I wrote most numbers in binary form, so it will be easier (at least for me) to see which LEDs are enabled and which flags are set.
Step 3: Example #1: Code
The code is written in AVR Assembly. If you work with controllers like ATTiny - it is a must! It looks scary, but in reality it's much simpler and easier than C.
Another reason for using assembly language is that this code only needs 148 bytes of space after compilation, while Arduino IDE produces 644 bytes of binary output for the same code (haven't tested in AVR GCC), so if you want to expand functionality of your Tiny project, you have less than 400 bytes left to work with...
* Shift register demo #1
* ATTiny13A Running @9.6MHz
* ADC running @150kHz
* PIN ASSIGNMENT:
* PB0 - Shift Register Clock
* PB1 - Shift Register Serial Data
* PB2 - Shift Register Latch(Store)
* PB3 - ADC3 (Potentiometer input)
* PB4 - [NOT USED]
* PB5 - RESET
.include "tn13Adef.inc"
.def A = R16 ; g.p. variable and/or function argument
.def B = R17 ; Used in SEND_BYTE and ADC_START as temporary storage
.def LED = R18 ; stores current LED output
.def BCT = R19 ; Bit counter for SEND_BYTE
.equ SRCK = 0 ; PB0 = Clock
.equ SRDA = 1 ; PB1 = Serial Data
.equ SRLC = 2 ; PB2 = Latch
/* INTERRUPT VECTORS */
.org 0x0000
rjmp RESET ; Reset interrupt
.org 0x0003
rjmp TC0_OV ; Timer1 interrupt
* START!!!
RESET:
/* SETUP STACK */
ldi A, low(RAMEND) ; Set stack pointer
out SPL, A
/* SETUP PINS */
ldi A,0b0000_0111 ; Set output pins PB0..PB2
out DDRB,A
/* SETUP TIMER1 */
ldi A,0b0000_0101 ; Set Timer Prescaler (1024)
out TCCR0B,A ; This will cause Timer Interrupt every ~27ms
ldi A,0b00000010 ; Enable Timer0 Overflow Interrupt
out TIMSK0,A
/* SETUP ADC3 */
ldi A,0
out ADCSRB,A ; Disable autotrigger(Free running)
ldi A,0b00001000 ; Disable Digital Input on PB3(ADC3)
out DIDR0,A
ldi A,0b00000011
out ADMUX,A ; Source:ADC3, Align:RIGHT, Reference:VCC.
ldi A,0b10000110
out ADCSRA,A ; Enable ADC with prescale 1/64
/* RESET REGISTERS */
ldi A,0x00 ; clear A
ldi LED,0xFF ; Set all LED's to OFF(1-off, 0-on)
rcall SEND_BYTE ; Clear display
sei ; Enable interrupts
/* Main loop */
MAIN:
rjmp MAIN
* Sends 8-bit data from LED register to Shift Register
SEND_BYTE:
ldi BCT,0b1000_0000 ; Set Bit counter
next_bit:
mov B,LED ; Move data byte to temp
and B,BCT ; Check bit
breq zero ; Set Data to 0
sbi PortB,SRDA ; Set Data to 1
rjmp shift ; shift
zero:
cbi PortB,SRDA
shift:
sbi PortB,SRCK ; CLK up
nop
cbi PortB,SRCK ; CLK down
clc ; Clear Carry flag
ror BCT ; Shift bit counter
brne next_bit ; Next iteration
sbi PortB,SRLC ; When done, Latch
nop
cbi PortB,SRLC
ret ; Done
/* Start ADC conversion. Saves result to A */
ADC_START:
sbi ADCSRA,ADSC ; Start ADC conversion
adc_wait:
sbic ADCSRA,ADSC ; Check conversion status
rjmp adc_wait ; Skip jump if completed
in A,ADCL ; Get low bits
in B,ADCH ; Get high bits
lsr B ; Shift 2 bits to the right
ror A ; through Carry
lsr B
ror A
ret
/* Timer 0 overflow interrupt */
TC0_OV:
rcall ADC_START ; start ADC0 Conversion
/* Compare Input, Set output */
cpi A,0xC8 ; A>=200?
brlo gt_160
ldi LED,0b11100000
rjmp sr_write
gt_160: ; A>=160?
cpi A,0xA0
brlo gt_120
ldi LED,0b11110000
rjmp sr_write
gt_120: ; A>=120?
cpi A,0x78
brlo gt_80
ldi LED,0b11111000
rjmp sr_write
gt_80: ; A>=80?
cpi A,0x50
brlo gt_40
ldi LED,0b11111100
rjmp sr_write
gt_40: ; A>=40?
cpi A,0x28
brlo lt_40
ldi LED,0b11111110
rjmp sr_write
lt_40: ; A<40
ldi LED,0b11111111
sr_write:
rcall SEND_BYTE ; Send byte to shift reg.
reti ; returnStep 4: Example #2: [INPUT]
As strange as it sounds, handling multiple digital inputs with a shift register is almost the same as handling multiple outputs. Let's look at the circuit first, so I can explain how it works.
Diodes are added to protect the outputs of the shift register, since multiple HIGH inputs may cause a short circuit. PB3 is connected to the ground through a 10K resistor (logical 0 when no match found).
The general idea is to send a certain set of data bits to the shift register and if there is a bitwise match with the input - we will get HIGH signal on PB3. For example, we have an 8-bit input 0x91, which is 10010001 in binary.
We start with sending 0x01 to the shift register (0b00000001) and see if the first bit is 1. If we have a match (PB3 is HIGH), we perform OR operation of the input to the result. Next, we shift the test data 1 bit to the left, so we get 0x02 (0b00000010) and repeat the procedure to acquire the second bit, which gives no match and results in logical 0... and so on until we test all 8 bits.
| Shift Register | PB3 | Result |
| 00000001 | 1 | 00000001 |
| 00000010 | 0 | 00000001 |
| 00000100 | 0 | 00000001 |
| 00001000 | 0 | 00000001 |
| 00010000 | 1 | 00010001 |
| 00100000 | 0 | 00010001 |
| 01000000 | 0 | 00010001 |
| 10000000 | 1 | 10010001 |
This technique allows to read reasonably large array of inputs at the cost of acquisition speed only. It does not require any additional pins, so it is a perfect solution for low-speed applications, like keypads, switchboards, or even low-speed digital sensors. The number of used pins can be further reduced, if we alternate Serial Data pin of the microcontroller between digital output and digital input(instead of PB3).
For our next example we will use almost identical circuit, but instead of digital inputs and transistors we will use simple tactile switches.
Step 5: Example #2: CODE
This code is much smaller and simpler than the previous example, because this time we are not using ADC. As you can see, SEND_BYTE subroutine is unchanged and does pretty much the same thing.
/* * Shift register demo #2 * ATTiny13A Running @9.6MHz * * PIN ASSIGNMENT: * PB0 - Shift Register Clock * PB1 - Shift Register Serial Data * PB2 - Shift Register Latch(Store) * PB3 - Digital input(bit match) * PB4 - LED * PB5 - RST * */ .include "tn13Adef.inc" .def A = R16 ; g.p. variable and/or function argument .def B = R17 ; Used in SEND_BYTE and ADC_START as temporary storage .def LED = R18 ; stores current LED output .def BCT = R19 ; Bit counter for SEND_BYTE .def TIM = R20 ; Stores how many iterations of TOV0 have passed .def TMP = R21 .equ SRCK = 0 ; PB0 = Clock .equ SRDA = 1 ; PB1 = Serial Data .equ SRLC = 2 ; PB2 = Latch /* INTERRUPT VECTORS */ .org 0x0000 ; Reset interrupt rjmp RESET .org 0x0003 rjmp TC0_OV ; Timer0 Overflow interrupt /* * START!!! */ RESET: /* SETUP STACK */ ldi A, low(RAMEND) ; Set stack pointer out SPL, A /* SETUP PINS */ ldi A,0b0001_0111 ; Set output pins PB0..PB2(CLK,DATA,LATCH) out DDRB,A ; PB4 - LED output /* SETUP TIMER0 */ ldi A,0b0000_0101 ; Set Timer Prescaler 1/1024 out TCCR0B,A ; Interrupt every ~27ms ldi A,0b00000010 ; Enable Timer0 Overflow Interrupt out TIMSK0,A ; /* RESET REGISTERS */ ldi A,0x00 ; clear A ldi LED,0x10 ; Default blink speed(~1Hz) sei ; Enable interrupts /* Main loop */ MAIN: ldi A,1 ; Set the first bit ldi TMP,0 ; Temporary storage for new LED delay next: rcall SEND_BYTE ; Send A to Shift Reg. sbic PINB,3 ; Check for match or TMP,A ; Add it to result clc ; Clear carry rol A ; Rotate A breq check ; If A==0, check and start over rjmp next ; else get next bit check: ; Only assign non-zero values tst TMP ; TMP==0? breq MAIN ; skip mov LED,TMP ; else assign new LED delay rjmp MAIN /* * Sends 8-bit data from A register to Shift Register * (Same as in the prev. example) */ SEND_BYTE: ldi BCT,0b1000_0000 ; Set Bit counter next_bit: mov B,A ; Move data byte to temp and B,BCT ; Check bit breq zero ; Skip if 0 sbi PortB,SRDA ; Send Data rjmp shift ; shift right zero: cbi PortB,SRDA shift: sbi PortB,SRCK ; CLK up nop cbi PortB,SRCK ; CLK down clc ; Clear Carry flag ror BCT ; Shift bit counter brne next_bit ; Next iteration sbi PortB,SRLC ; When done, Latch nop cbi PortB,SRLC ret ; Done /* Timer 0 overflow interrupt */ TC0_OV: inc TIM ; TIM++ cp TIM,LED ; TIM>LED? brlo early ; too early push TMP ; Save old TMP value in TIM, PINB ; Read current port state ldi TMP, 0x10 ; eor TIM,TMP ; Toggle PB4 out PORTB, TIM ; ldi TIM,0 ; Reset counter pop TMP ; Restore TMP early: reti ; return
Step 6: Additional Resources
If you are new to AVR Assembly and you feel intimidated by cryptic opcodes and registers, but you think you are ready to conquer the world of microcontrollers, these are good places to start:
