Introduction: Getting More Out of Your Cheap Digitizing Embroidery Software
Several years ago I purchased some digitizing software for my Husqvarna Designer I.  I didn't buy the top of the line software, but what I did buy (4D Embroidery Extra) didn't work as well as I thought it should.  I expected it to be able to give me a nice stitched pattern from a simple/cartoon drawing, but I had a lot to learn.  Being stubborn and without enough funds to purchase the top of the line software, I determined to get my money's worth.  After some research, and a lot of trial and error, I found a way to improve the results from my software without any extra money... but with a lot of effort.  This Instructable may help you get better results from your existing software if you want to invest the time, I made it for a friend who wanted to know how I made the dragon in the main image.
Step 1: Overview
Here are the big issues I had with my software:
1.  Any raster format image (jpg, bmp) has to be very clean without any extraneous pixels or colors to process well
2.  Colors - the software tries to make like colors the same and blend them all into one stitch section, or turn light colors into white which can be accidentally deleted when removing "background" color
3.  Black is always treated as an outline area and by default the software will try to narrow black areas, or not be able to stitch the area at all
4.  "options" don't appear to make much difference and satin vs. fill stitches can be applied haphazzardly
5.  While making the images for this Instructable I found that my "new" computer could process images the old one couldn't (more processing power makes a world of difference).  The Chinese image of the birds crashes on my old computer.
For best results you want to have a clean image in a vector format (for a good explanation of vector vs. raster files see this video by artexlabel https://www.youtube.com/watch?v=YurPdfuDj6M ).  You can spend a lot of time cleaning up raster files (which I did initially) or go for a vector format image which will digitize better.
My 4D software only reads WMF vector files.  I used Libre office to export to WMF - cause it is FREE! (http://www.libreoffice.org/), But the main thing is to have a graphics program that supports objects and can save or export to WMF.
Step 2: Good Digitize With a Vector Image
1.  I took a line drawing from Lora Irish's "Great book of dragons"
2.  In Libre office draw, I traced each discreet area I wanted stitched with a "freeform line filled" (yeah this takes forever if the image is big).  You don't have to trace the lines exactly, just make sure foreground objects are right sized, and you can be sloppy with the objects lower in the image stack
3.  I then color coded the areas in alternating primary colors to ensure the software would not blend them together
4.  I exported the file into WMF format then impoorted into my software
5. Once I have a decent image design, I color changed areas so that they look how I want the final design to stitch out (Note:  the dragon's underbelly which in the design is dark brown was stitched in variegated thread)
Step 3: Other Images
Images of another successful dragon
