Getting Started With Ultrasonic Sensor in 3 Simple Steps
Intro: Getting Started With Ultrasonic Sensor in 3 Simple Steps
Hey everybody,
Before starting this instructable let us know what an ultrasonic sensor is.
Ultrasonic Sensors are self-contained solid-state devices designed for non-contact sensing of solid and liquid object.
So there ends the technical definition,I don't know how many of you understood.In simple words, its a sensor which helps us in knowing the proximity of the obstacles or objects.We here in ECE see every object as an obstacle
STEP 1: Components Needed
1. Ultrasonic Sensor
2. Jumper wires
3. Arduino Uno
4.Breadboard
5.LED(Add-on)
STEP 2: Step 2: Make the Connections
- Vcc to 5V
- Gnd to Gnd
- Trig(Trigger) to digital pin 9(any of your choice)
- Echo to digital pin 10( again,any of your choice)
- LED to digital 12(You can use built-in LED if you want)
- And yes, don't forget to connect Arduino to your laptop(happens to me quite often ;) )
STEP 3: Step 3: Run the Code Printed Below and You Are Good to Go
int trig=9;
int echo=10;
int a=12;
void setup()
pinMode(a,OUTPUT);
Serial.begin(9600);
void loop() {
long duration,cms,in;
pinMode(trig,OUTPUT);
digitalWrite(trig,HIGH);
delayMicroseconds(10);
digitalWrite(trig,LOW);
pinMode(echo,INPUT);
duration=pulseIn(echo,HIGH);
cms=mtoc(duration);
in=mtoi(duration);
if(cms<=10)
digitalWrite(a,HIGH);
else
digitalWrite(a,LOW);
Serial.print(cms);
Serial.print("cm");
Serial.println();
long mtoc(long m)
return m/29/2;
Points to note:
- LED will light up once the distance is less than 10 cm. This can used as a warning to the user in practical applications.
- Serial monitor can be used to see the distance.
- The video has been uploaded for your convenience
PushpendraC2 6 years ago
The code is showing error
